I had to laugh!!
oze30
Fri Mar 21, 2008 8:11 pm
Check this out!
How anyone can buy this...
http://cgi.ebay.co.uk/FUEL-PUMP-BOOST-B ... dZViewItem
Just astounds me!!
JGG1
Back in an E30 !
Fri Mar 21, 2008 8:16 pm
"Car manufacturers use wire that is far too thin to provide the large power demands of modern fuel pumps"
I knew there was something wrong with my touring!!! :snigger:
wackiacki
Fri Mar 21, 2008 8:22 pm
i realy need the 34% increase in voltage to my headlamps,can't see jack most of the time!!!! :mad:
murran
Fri Mar 21, 2008 8:52 pm
you seen the other items that are forsale? what a lot of crap! :mad:
e21 killing tyres with e30 325 powerzzz
drifting on the cheap......... www.trampdrift.com
e21zone........ www.bmwe21.net
josh-hocking
Teenager with Taste !
Fri Mar 21, 2008 9:00 pm
:) lol someone will buy it those :mad:
Steve-E30
East Sussex Hooligan
Fri Mar 21, 2008 9:02 pm
One feedback recieved ...
Positive feedback rating gains of power are small but necessary for any high reving car.
Its a joke yeah :mad:
Giggety Giggety Goo!!!
fuzzy
He who sleeps with "Gingers"
Fri Mar 21, 2008 9:10 pm
over 10000 sales with a 99.4 positive rating? it must be true if it says it on ebay.
"If your engine does not receive enough fuel at high-rpm, it can melt pistons and destroy your engine in seconds. Protect yourself now!"
wow , the answer to melting pistons at high boost. a bit of wire and a fuse. ill need to enlighten the cosworth owners as it will be the answer to their prayers.
--alpina--
Sat Mar 22, 2008 1:22 am
Reckon if i buy this excellent piece of kit, i could make my car that little bit faster??? :D :D
j
Uk`s first E21 - Forum -
http://www.e21.ownforum.org
chinchilla
Sat Mar 22, 2008 10:42 am
i just bought one :o:
Yaninnya
Sat Mar 22, 2008 11:39 am
The auction text is rubbish, but the whole idea is not dumb. I remember, in Lancias Integrale and Fiats Coupe Turbo there was a problem with fuel over 330 BHP and the cheapest solution was new fuel pump feed wire with a section 2.5 mm2 at least. That was increasing fuel efficiency by ca. 25 - 30 l/hr.
Jan
cliffybabe
Powered by Nelly
Powered by Nelly
Sat Mar 22, 2008 1:03 pm
:lol: people will rush out and buy this its unreal
bazcoupe
Sat Mar 22, 2008 1:10 pm
demon tuning strikes again
not the first time this companys come up on here. :mad:
SHAKEELE30
Boost Junkie
Sat Mar 22, 2008 1:13 pm
bet you would if it was chrome :D
cliffybabe
Powered by Nelly
Powered by Nelly
Sat Mar 22, 2008 1:14 pm
SHAKEELE30 wrote:bet you would if it was chrome :D
:lol: :roll:
harry_p
Sat Mar 22, 2008 8:32 pm
the idea behind it isnt silly, but the wording is rather ott.
wiring and connections do deteriorate over time, and a lot of e30s are getting on for 20 years old now. a similar setup is often used on older cars to help make the headlights a bit more useable.
ok, so it's not suddenly going to give your car loads of extra power, but it could be worth doing in some cases, and if youre going to the trouble of overhauling a lot of the rest of the car, then it makes sense to pay some atterntion to the electrical system too.
the price isn't even too bad either. if they were £50 a pop then they would definately be taking the pi$$ and certainly not be worth it.
i have done silimar to my lancia, i'm only running 260bhp, but had the parts needed sitting in the garage and an hour spare, and it cant cause any harm either. used some decent cable and connectors and a good clean, solid dedicated earth point for the fuel pump, just used the factory wiring to trigger the new relay. not going to claim i noticed a difference, but a lot of people i know have measured a large voltage drop at the pump with the standard wiring, and it seems sensible to me to try and minimise this.
cheers,
harry
