Suggestion - Technical FAQ section
Do the "management" feel it would be a good idea to compile a list of the most frequently asked questions and then do a belt & braces response to each technical query and then either sticky the lot or have a separate Technical Help FAQ section.
I'm always happy to help a newbie or anyone else where i feel I know the answer, but it gets a bit tedious seeing the same questions asked all the time.
I know people rarely use the search function, but this may help.
What are the views on this?
SHAKEELE30
- Boost Junkie
Not sure if you wanted zoners opinion or the mods opinion, but i think that'll be a good idea, cos ive noticed alot of similar questions keep coming up, hardly anyone uses the search function. I use it but sometimes its a bit useless, cos it brings up everything with the words you type in the search, which is a bit tedious at times.
But overall think its a good idea....See what the mods think
march109
- Contact:
Possible candidates are the questions
How do I get more/How much power from my M40/M10/M20?
How do I turbo?
Cheapest/easiest way to 5stud conversion?
I've got a leak/wet foot wells?
Gearbox/Engine/Diff oil recomendations?
and the rest.
How do I turbo?
and the rest.
richie_zone
You can use the search function more accurately if you use the options provided.
But a Tech FAQ sounds like a great idea.
What would be an example of the top 10?
- **BANNED**
Most of the FAQ are now stickied,to put them in a seperate section may just cause more confusion. May be better to extend the 'articles' section and add the stickies there? Afterall,we now seem to have two places with this sort of information... is there any way of making the search function more user friendly?
Youth is wasted on the young.
march109
- Contact:
Articles/threads written for most common questions not yet covered would be cool.
If the articles section were then edited to have links to the specific threads regardless of what forum section they are stickied in in would be a one stop resource shop withought having to look through the forums.
well to rob an example from a Soarer forum, this is kind of what I had in mind
B
B
Battery - what is the official one ?
Toyota 'Optifit' - part no: 28800 YZZAG : post 15 - http://www.toyotaimportsforum.co.uk/...&highlight=EMV
Powerful batteries that fit a Soarer: http://www.toyotaimportsforum.co.uk/...ad.php?t=21395
Belts
The 'serpentine' ancillaries drive belt: http://www.toyotaimportsforum.co.uk/...ad.php?t=23651
BFI - what is it ?
http://www.toyotaimportsforum.co.uk/...ghlight=intake
Blinkydash - digital instrument display - intermittent failure
http://www.toyotaimportsforum.co.uk/...ead.php?t=2596
Blitz Dual SBC - how do I configure ?
http://www.toyotaimportsforum.co.uk/...&threadid=4889
Boot lock release
Fuse: http://www.toyotaimportsforum.co.uk/...ad.php?t=10236
Releasing the lock on dash / fascia: Post 6 - http://www.toyotaimportsforum.co.uk/...ead.php?t=6532
Boot struts - replacing with cheaper parts
http://www.toyotaimportsforum.co.uk/...ead.php?t=8103
BOV - what does it do ?
http://www.toyotaimportsforum.co.uk/...ight=induction
Brakes - all about them
http://www.toyotaimportsforum.co.uk/...?threadid=7314
http://www.toyotaimportsforum.co.uk/...akes+serv ice
Brake calipers - freeing a seized bolt
http://www.toyotaimportsforum.co.uk/...ad.php?t=10648
Brakes - Error code 51
http://www.toyotaimportsforum.co.uk/...ighlight=error
Brakes - Error code 56
http://www.toyotaimportsforum.co.uk/...ht=translation
Brake fluid - what type ?
http://www.toyotaimportsforum.co.uk/...ead.php?t=7680
Brakes juddering - what's causing it ?
Siezed calipers: http://www.toyotaimportsforum.co.uk/...ad.php?t=13548
Brake lamp - high level
http://www.toyotaimportsforum.co.uk/...&threadid=3911
Brakes - noise of pump operating when braking
http://www.toyotaimportsforum.co.uk/...ght=brake+pads
http://www.toyotaimportsforum.co.uk/...ad.php?t=16080
ABS pump keeps running: http://www.toyotaimportsforum.co.uk/...ht=accumulator
Brakes - pads
Sizes: Post 29 onwards: http://www.toyotaimportsforum.co.uk/...s&pagenumber=1
Various makes: http://www.toyotaimportsforum.co.uk/...ght=brake+pads
Brakes - servicing
http://www.toyotaimportsforum.co.uk/...rake+servic e
Brakes upgrade - AP Racing
http://www.toyotaimportsforum.co.uk/...hlight=bad+boy
B
B
Belts
BFI - what is it ?
Boot lock release
Brakes - pads
Brakes - servicing
C
Cs supercharger - on a V8
http://www.toyotaimportsforum.co.uk/...ead.php?t=3806
Cambelt change - for a V8
http://www.toyotaimportsforum.co.uk/...ad.php?t=10552
http://www.toyotaimportsforum.co.uk/...ead.php?t=1628
Cambelt change - for a TT
Picture guide: http://www.toyotaimportsforum.co.uk/...ad.php?t=18533
Car tests - Autospeed magazine
V8 4.0-litre Soarer: ....................................http://autospeed.com/cms/article.html?&A=0062
Straight 6 2.5-litre twin turbo Soarer:...........http://autospeed.com/cms/article.html?&A=1187
Straight 6 2.5-litre single turbo VVT-i Soarer http://autospeed.com/cms/A_109457/article.html
Straight 6 3-litre naturally aspirated Soarer:..http://autospeed.com/cms/article.html?&A=0884
CD player / changer / stacker - why won't it work properly?
http://www.toyotaimportsforum.co.uk/...t=reset+button
http://www.toyotaimportsforum.co.uk/...ead.php?t=7576
Central locking - curing intermittent problems of various types
http://www.toyotaimportsforum.co.uk/...ad.php?t=16306
Centre console/head unit - how do I remove?
http://www.toyotaimportsforum.co.uk/...&threadid=6758
Climate control - fresh air vs recirculation
http://www.toyotaimportsforum.co.uk/...ad.php?t=12860
Climate control 94 TT - can I replace the LCD display ?
Computer - install a touchscreen computer instead of the EMV to handle GPS, Audio, Video & car stat's data
http://www.toyotaimportsforum.co.uk/...ad.php?t=15043
Cooling - transmission and oil radiators
http://www.toyotaimportsforum.co.uk/...s sion+cooler
Crank shaft pulley nut - how to remove
http://www.toyotaimportsforum.co.uk/...ad.php?t=12518
Cup holder
Cupholder still available in Spruce Green: http://www.toyotaimportsforum.co.uk/...875#post138875
Fitting the cupholder: see Post 2: ............http://www.toyotaimportsforum.co.uk/...875#post138875
Cup holder
- **BANNED**
I reckon your have just found yourself a job,Lee,after the engine swap...of course...
2010 planned for roll out then
Just posted something similar on one of these repetitive threads. On the M42 forum they have a section called "How-To's" full of guides on how to do things, this is treated like any other section of the forum but threads can only be started if they are guides so are deleted if they are questions. These can be replied to though so anyone can ask a question or maybe politely point out a mistake.
I know the zone already has an articles section but this rarely gets updated, has very limited content and i doubt many people who use the zone have even looked in it.
Just my 2p
Just my 2p
snoops
- Major Helmet
e30tech.com has something similar with their faq section
a common question I see very often is something along the lines of 'Aramil's' question in the tech section now 'Looking at an E30 tomorrow... Things I should look out for?!'
I think central locking and poor idle problems would be the top two on the list. Brians wearing his keyboard out with those little beauties.
An FAQ section would be a great idea but it would take a fair bit of research, composition amd tabulating in order for it to be a success. If there are any volunteers?
TRANSPORTER
I,ve got to agree with the top 2 being Idle problems and central locking, How many times do we see a thread with idle in it, and how many times do people not complete the thread and inform when they have sorted the problem leaving the rest of us scratching our heads as to what the solution actually was to their problem, after we gave them many probable causes as to what was the cause of the problem.
THERE ARE AIMERS, USERS, MOTORISTS AND THEN DRIVERS
richie_zone
Need a solid list before people can volunteer to write-up / do a thread.
There are already some really good ones in the Tech Articles, just need an extrapolation of those.
I'd say, in no order of importance:
1. Idle Issues
2. Central Locking Issues
3. 4-5 Stud Conversion
4. Leaky foot-wells / boot
5. Stopping rust (temporarily)
6. Diff problems
7. Lowering advice
8. Correct wheel offset for various models / camber / tyre size etc
9. ICE
10. Overheating
1. Idle Issues
6. Diff problems
7. Lowering advice
9. ICE
10. Overheating
Cloggy Saint
12. Speedo not working
13. instrument cluster not working
14. Fan only works on full blast
I think the list will be ever growing, thats why the way it's been done on the M42club works as anyone can write up a guide and post it, it would just need someone to moderate it that would know how accurate the guides are and that they are useful and make sense.
The thing is we already have tech articles and stickies and nobody seems to use these and don't even get me started on the Links section which has not only all the ETM (wiring diagrams) but also the genuine BMW workshop manual (Better than Bently).
People are just too lazy
Rant over
Could be a good idear but they would only be of true improvement over whats already here if properly photographed.
Rant over
If I can't fix it I'll f**k it up so bad nobody can!!
Just looked in the links section and found the wiring diagrams but not the workshop manual. Where is this?abelai wrote:The thing is we already have tech articles and stickies and nobody seems to use these and don't even get me started on the Links section which has not only all the ETM (wiring diagrams) but also the genuine BMW workshop manual (Better than Bently).
People are just too lazy![]()
Rant over
Links/"how to" guides/ workshop manual
