318i lux master cylinder upgrade
james318i
Mon Mar 03, 2008 5:33 pm
my cars going to be treated to a new master cylinder shortly , before i go and buy a std 318i one is there anything off another bmw model that will fit it and have a bigger piston etc and a bit more stopping power , fitted bigger master cylinders to motorbikes etc but not sure its something you can do on a car ?
if ive got to replace i may aswell upgrade at the same time
james
smithy318i
Mon Mar 03, 2008 5:51 pm
Your foot is the adjustment for the stopping power of the brakes.
ed325i
Mon Mar 03, 2008 6:13 pm
You can fit the bigger m/c from a e32 750.
BadDave
Mon Mar 03, 2008 6:28 pm
TBH it's not really necessary
I've run the std M/C with my 4 pots with no probs
As ed says, you could fit the 25mm one from the e32 750i
The 23mm one from an E30 M3 also fits
Unless your using calipers fitted with pistons way larger than std, there's not really any need to fit a larger diameter master cylinder
