Dash removal
howie
Tue Feb 26, 2008 5:09 pm
anyone know of a thread that was on here for removing the dash, thot i saw one on here a while back
blyoss
Tue Feb 26, 2008 5:42 pm
i too, would like to remove my dash and replace with a new one
cliffybabe
Powered by Nelly
Powered by Nelly
Tue Feb 26, 2008 6:04 pm
Gwynleym10
Tue Feb 26, 2008 9:06 pm
Its easy!
Got a none cracked one if anyone wants it...
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
tezk
Tue Feb 26, 2008 9:36 pm
Gwynleym10 wrote:Its easy!
If you take your time and carefully maneouvre over the steering column (by far the trickiest bit of refitting) you'll be fine.
Though I'm pretty patient and it had me swearing winkeye
Tue Feb 26, 2008 9:49 pm
Lots of that doesnt need to be removed, most of page 4 should be ignored
tailoutcharlie
Tue Feb 26, 2008 9:50 pm
apparently you can just unplug all the connections above the rear of the glovebox and you can take the whole dash out with everything stil attached,
at least thats what brianmoooore said and whens he wrong :D
Chris
PISTONS
Tue Feb 26, 2008 11:21 pm
True, ive taken out dashes in like 5 mins without whipping the steering wheel out, ive actually done it in pitch black darkness, dont ask why, i still have nightmares thinking about it. :D :D :D
Actual fact ill say, i took it out in the dark cos i wanted to fit my M3 dash in as i couldnt wait, reality i used a lighter with a mate holding it as a light but it was as good as pitch black!!!
j
blyoss
Tue Feb 26, 2008 11:26 pm
When you say you've taken them out in 5 mins, is that leaving it in good enough condition to refit a new one. Im looking for a new uncracked one
agreen
Tue Feb 26, 2008 11:49 pm
see above
blyoss
Wed Feb 27, 2008 12:54 am
how much would you want for it. your also a little out of my way
BadDave
Wed Feb 27, 2008 4:57 pm
Howie
It's a pretty straight forward job mate
As we discussed last night
If you need a hand,gimme a shout
BadDave
Wed Feb 27, 2008 5:00 pm
tailoutcharlie wrote:apparently you can just unplug all the connections above the rear of the glovebox and you can take the whole dash out with everything stil attached,
It is indeed true
Just need to unplug the middle connector behind the glove box and it can all come out in one
