Rusted rear
craige30
Post Wed May 25, 2005 1:35 pm
Just realised the rust bubbling up on the corner of the drivers side rear valance on my 1988 316i 2 door has come through from the boot. Looks like water has got in through the boot and collected in the rear "well" and rusted through.
Is this a problem with E30s ? God knows if it can be fixed.
parksie
Post Wed May 25, 2005 5:13 pm
I'm having mine fixed at the moment, probably just the same fualt mine needs a new rear panel Ԛ£43 + vat and quite a bit of metal work welding in !!!.
I've got to the point of no return, my baby's got to look good, after the body work restoration and respray i think she will.
e30symphony
Post Wed May 25, 2005 5:45 pm
I bought a '87 318i last month and am after finding five patchs of rust around the boot and the whole rear passenger side wheel arch has to be replaced, Its not all bad i got her for 200 euros. Have you took out all the carpet in the boot to see if there is more rust, there usually is.... :cry:
craige30
Post Sun May 29, 2005 7:10 pm
Thanks for the responses. Yeah, mine has rusted through from the boot floor. It will take a good bit of welding new metal in I guess. Rear panel for Ԛ£43, doesn't sound too bad. Thing is, if this is fixed she's tip-top. 134,000 miles and runs great (apart from fuel smell which is coming from leaking fuel pipes, also common acccording to the forum).
