i had an ocean in my boot =|
tg318is
Mon Feb 11, 2008 7:25 am
i have a '90 318is and i was away for 5 days and it rained all days i was away i put my bag in my boot this morning and there was water where my jack is, atleast 15cm deep :eek: . anyone know how the water could get there?
cheers
Cloggy Saint
Mon Feb 11, 2008 7:38 am
Rear light seals is the usual suspect for water in the boot space.
E30Mark
Mon Feb 11, 2008 8:27 am
Sunroof drain tubes, aerial, boot seal , light seals etc etc
Make sure the drain hole is cleared, look underneath and you should be able to see a half moon shaped bulge, clear it!
PM for details
tg318is
Mon Feb 11, 2008 9:11 am
ahh where do the sunroof drain tubes come out? and i think there is bog or something covering the drain hole.. cant find 1 on the inside or under.. heres a pic of where it flooded..
thanks
Chris-W
Mon Feb 11, 2008 9:15 am
The sunroof drain is the hose on the left of your pic, leading to the boot vent.
tg318is
Mon Feb 11, 2008 9:35 am
o.k thanks! and where ive circled, is that where the drain hole is meant to be?
tg318is
Mon Feb 11, 2008 9:36 am
or is that bit not ment to have water? (sorry hadn't finished last post)
stevotheevo
West Sussex Hooligan
Mon Feb 11, 2008 9:39 am
had the same problem mate, i just drilled a hole in it :D
toby
Mon Feb 11, 2008 4:05 pm
I had this problem and tightened up the rear light cluster and the ingress was solved.
HairyScreech
Mon Feb 11, 2008 4:43 pm
normaly the light cluster seals, i need to sort mine, join the club.
Kedge
Mon Feb 11, 2008 4:51 pm
Had the same mate, changed the light seals but turned out to be the boot seal, may as well do the lot at once as all the rubber will be breaking down by now.
Instagram - Kedge85
jcjdavis1
Mon Feb 11, 2008 10:32 pm
Hi. If your ariel is on that wing check for water coming in there.
tg318is
Tue Feb 12, 2008 6:14 am
Hey.. im pretty sure its the sunroof drain tubes.. i poured water all over the other parts you guys suggested and no water collected in the boot.. anyone know how to get to the sunroof drain tubes? would i need to take out the headliner?
Chris-W
Tue Feb 12, 2008 8:44 am
Check where the sunroof drain hose joins the plastic vent panel - it's hard to make out for sure in the photo, but it almost looks likes someone's splashed some mastic on the end already.
