Broken indicators please help
m3will
Post Wed May 18, 2005 9:06 pm
Hi i put a post up last night and now cant find it so ill do it again. My indicators in my m3 stopped working I changed the fuse and now the hazards work but they wont work off the stalk? i checked the black relay under the steering column it looks ok could it be the stalk itself? With the relay i pulled it off and the hazards wouldnt work put it back and they did but still not off the stalk. What should I do?
Bharat
Post Wed May 18, 2005 11:05 pm
Your post was probably moved to the Technical Section, as this is a Technical query, and you have posted in the wrong section again.
Please check your own Posts (using the Search function above) to see if that is indeed the case, before re-posting, as re-posting serves no purpose really, because someone might have replied to your original post.
Kindly use the older post. This one is being locked. Thank you.
325i Motorsport Edition convertible - gone, but not forgotten.
