oil leak?
tommye30
Thu Dec 13, 2007 8:26 pm
seem to have an oil leak coming from the passenger side of the engine and i have been told it could be coming from where the distributer would be. is this right
oh its a 325
tezk
Thu Dec 13, 2007 8:31 pm
Its certainly possible - the distributor is mounted on the end of the cam and the cam oil seal can develop leaks.
Its easy to check - take of the distrubutor cap and it should be oil free.
If there is oil its a relatively easy job to replace the seals..
trevski
Thu Dec 13, 2007 8:39 pm
mine leaked from the crank case breather not a bad job too do :P
