Picture req. for 100% complete toolkit
Sjoerd320i
Could someone please put up a pic of a toolkit that's in the bootlid that's 100% complete?
Oh. I have a towing hook for the front of the car but where am I supposed to keep that?
SHAZ325iSPORT
lance1a
- South African/Scottish import
depends on what tool kit you have there, the UK one is the small one with 4 spanners, plug socket and bar,pliers, screwdriver, space for locking nut, but some others (like the S A models) had a whole lot more like bulbs and fuses &
stuff.
BMW E28 528i X2
Merc W126 300E twin turbo
Merc cosworth 190e 2.3-16
BMW E28 525E
BMW E28 M535i
Saab 900 Classic Turbo
BMW E24 Highline Cosmos
BMW E24 Highline silver
BMW E24 Macau Msport
BMW 1972 2002
BMW E36 Alpina B3 3.2 Switchtronic
Renault
BMW E28 525E
BMW E28 M535i
BMW 1972 2002
Renault
Sjoerd320i
yeh I've seen those, they are huge, I've got the small one
lance1a
I think mine's complete I can take a pic in the morning for you,
if you don't get one by then?
BMW E28 528i X2
BMW E28 525E
BMW E28 M535i
BMW 1972 2002
Renault
BMW E28 525E
BMW E28 M535i
BMW 1972 2002
Renault
Sjoerd320i
If you would mate
lance1a
Told ya!
BMW E28 528i X2
BMW E28 525E
BMW E28 M535i
BMW 1972 2002
Renault
BMW E28 525E
BMW E28 M535i
BMW 1972 2002
Renault
Sjoerd320i
cheers guys
I'm missing the yellow thingey, I assume that's a wheel lock nut?
I do have safety bolts but they use a real key
I have to take a look if I have the litle pin that's half way inside the tubular thing and not sure on the gold imbus (is that how you call it?)
tom325sport
I think the yellow thingey is in case your windows get jammed or stuck, could be wrong though.
Hi Queston for Gazza325cab I have the same tool kit was wondering what the long spindle thing is (and what is it used for) in the middle of the spark plug socket , it looks like it fits into the screw driver handle(yes) any body any idea, joeboy
wheelie_lv
the same question, and maybe someone have the part Nr. ?joeboy wrote: what the long spindle thing is (and what is it used for) in the middle of the spark plug socket , it looks like it fits into the screw driver handle(yes) any body any idea, joeboy
90' E30 325i 2-door M-Technik 2
Sjoerd, long time no see. The little yellow (or it should be white) tool is the manual window tool for electric windows that are fooked.
Give Big Bavarian Beauties are call. They have 6 in stock at the moment.
@e30_daryll
skipunda
Isnt the window winder tool replaced by a locking wheel nut tool in this photo?lance1a wrote:I got the torch out.......I am assuming this is complete? I'm also sure I will get someone saying it ain't, but then that way you'll get your answer!![]()
Chris
SUMPCRACKER
SUMPCRACKER
I think the bar should go where the allen key is and there should be a bigger spanner there?
- gooner1
- Out humping Reindeer
Its used when changing a wheel, one end on the hub and slidewheelie_lv wrote:the same question, and maybe someone have the part Nr. ?joeboy wrote: what the long spindle thing is (and what is it used for) in the middle of the spark plug socket , it looks like it fits into the screw driver handle(yes) any body any idea, joeboy
wheel over it. Can also be used with the spark plug tool ,to loosen and tighten. Very handy.
wheelie_lv
any pictures and/or part nr. please !gooner1 wrote:Its used when changing a wheel, one end on the hub and slidewheelie_lv wrote:the same question, and maybe someone have the part Nr. ?joeboy wrote: what the long spindle thing is (and what is it used for) in the middle of the spark plug socket , it looks like it fits into the screw driver handle(yes) any body any idea, joeboy
(i'm speaking about that spindle in the middle of the spark plug socket)
I also found that the bar on the far right can be used to lock the engine when setting up the timing one day as well as using it for locating the holes for the wheels when fitting themgooner1 wrote:Its used when changing a wheel, one end on the hub and slidewheelie_lv wrote:the same question, and maybe someone have the part Nr. ?joeboy wrote: what the long spindle thing is (and what is it used for) in the middle of the spark plug socket , it looks like it fits into the screw driver handle(yes) any body any idea, joeboy
Never knew there was suppose to be a second bar inside the spark-plug tool... going to have to find myself one of those
