rims
spook
League two here we come !!!
Sun Nov 25, 2007 2:44 pm
whats the widest set of rims that will fit on a 4 stud e30, with no modifications, my arches are already rolled at the rear,
does it make any difference in the width you can go to by using 15 , 16, or 17inch rims
thanks spook :cool:
oakey
Sun Nov 25, 2007 6:21 pm
Youd be fine with 16X9" on the rear with stretched tyres. I personally wouldnt go wider on the front than 7.5/8"
spook
Sun Nov 25, 2007 6:31 pm
cheers oakey :cool:
oakey
Sun Nov 25, 2007 6:42 pm
Why what wheels you getting? winkeye
d1mmy
Boost Junkie
Mon Nov 26, 2007 1:41 pm
Also depends on the drop.
My 16X9j rub on the back with rolled arches and 60 or 80mm drop. Fronts no probs with 16X7.5J
For sale 325i Sport Turbo & 318i (Sport) M50B25
merkyboy
Mon Nov 26, 2007 6:32 pm
whats the likely ness of having to roll your arches with 17x8j, and a 60/40 drop(i think very high but i thought id ask) , and what tyres would you recommend.. i want stretched tyres, can any wheel tyre guy do this, or is it slightly more complicated. sorry to poach your thread, and sound like a numpt, but any help would be appreciated!
cheers merkyboy!
habeeb
Wed Nov 28, 2007 11:50 am
i have 9j all round and the arches are rolled, lowered it too much at the back 60mm , probably could use a 20mm drop at the back with wider wheels.
*Hardtop wanted*
ste
Wed Nov 28, 2007 1:51 pm
D1MYY wrote:Also depends on the drop.
It's not just the width and drop you have to consider the offset too. If you had a higher offset, providing you've got inner arch/damper clearance you'd gain clearance at the arch and you'd probably be fine.
aceraf
Wed Nov 28, 2007 1:55 pm
Aren't most 9j wheels that fit an e30 et15?
Also wouldn't a higher offset mean going through rear tyres very quickly?
I'm think that my borbet t's are et15.
Breaking 325i Touring
