M-SPARKS
Wed Nov 07, 2007 9:08 am
Hi guys, Im trying to restore a 89 325i motorsport cabby, the power hood seems to have given up and from what the mecanic is saying to me it could be an expensive repair.
So, is it possible to convert the power hood to a proper manual hood and if so what would be involved ?
DaveD
- E30Zone Wiki Specialist
Wed Nov 07, 2007 9:16 am
If you still have the motor it should not cost more that £250 to repair an electric roof...on a motorsport its worth it
gra325i
- E30 Zone Meets/Events Team
Wed Nov 07, 2007 1:17 pm
my local specialist has recommended a manual hood too as the electric one gave up the ghost he reckoned at least £400
DaveD
Wed Nov 07, 2007 6:18 pm
depends whats wrong
a repair main lift motor (new top from jason) £100
a secondhand flap motor (these don't go very often ..same source £50)
new rods and knuckle joint ;£47 from the dealer
+ fitting which is not a too difficult job
gra325i
Wed Nov 07, 2007 7:08 pm
think i may look into that when it comes cabby rebuild time then..someone mentioned faulty micro switches but i noticed that the rod has been broken at some point and welded back together (badly)
M-SPARKS
Wed Nov 07, 2007 7:52 pm
Cheers guys
Im not to sure which part is giving trouble yet, Its hopefully going back to my mechanic next week so if the cost wasn't huge I would love to get it repaired as I'm trying to put the car back to original form.
Jimb
Thu Nov 08, 2007 2:05 am
But can't you just disconnect the passenger side rod so that onlt the boot lid opens and then you lower the top manually?
Jim
mrLEE30
Thu Nov 08, 2007 6:22 am
Jim
yes you can, but as you say you need to open the roof cover electrically
