318is engine mods?????
Shane325i_sport
Sun Oct 28, 2007 2:19 pm
I have a totally standard 318is and i want to know what i could do to give it more power, apart from an engine conversion.......
maxfield
Sun Oct 28, 2007 2:21 pm
Depends how much you want to spend...
You could go F/I, go for a full N/A build or just bolt a few bits on...
Shane325i_sport
Sun Oct 28, 2007 2:23 pm
Dont want to do anyting major to it, what few bits could i just bolt on???
maxfield
Sun Oct 28, 2007 2:24 pm
ITG air filter.
BBTB.
Cams.
Exhaust - OE will be spot on.
Remap.
Shane325i_sport
Sun Oct 28, 2007 2:29 pm
Whats BBTB?
march109
Sun Oct 28, 2007 2:35 pm
Big bore throttle body.
6-Shooter
Sun Oct 28, 2007 2:36 pm
Big Bore Throttle Body.
Some people think this does nothing though.
With the M42, a re-map / chip is probably the only thing worth the money.
Cams are expensive for what they yield, exhaust - again opinion is divided and even Performance filters have been seen to reduce power in some cases.
So before you go throwing loads of money away, think about what you want (and need) and theh go that route.
If it's lots of power then you have to go Forced Induction.
I have not mentioned engine rebuild as lighter pistons, hotter cams, ti-con rods, capacity and compression etc is insane money for an E30 318iS.
I would go with a re-map and perhaps the BBTB as it shouldn't set you back more than £500 for both - then if you still want more - you may have to get a new engine / car.
Shane325i_sport
Sun Oct 28, 2007 2:38 pm
Cheers lads....
maxfield
Ti-con rods :eek:
I wouldn't want to think how much they are. Although you'd only want them if you were going stupid revs..
6-Shooter
Sun Oct 28, 2007 2:46 pm
I was just stating how far you can go on any project - but at some point you have to drop a reality check.
alex-e30
Sun Oct 28, 2007 3:45 pm
take a look round the evolve zone shop, you can get some well priced engine mods there.
a stantard e30 318is runs at 136bhp so if you start pumping stupid brake out of it things will start breaking so think about the bottom end con-rods etc...............thats if you go crazy with mods
this is my beemer, there are many like it but this ones mine
(OO=[][]=OO)
maxfield
Sun Oct 28, 2007 3:51 pm
I think all the bottom end is forged anyway...
It's not the amount of BHP that will break the engine, it's how much PSI you are using or how many revs you're going to..
fuzzy
He who sleeps with "Gingers"
Sun Oct 28, 2007 3:52 pm
turbo is the way to go for meaningful power increases and easy/cheap future power upgrades.
6-Shooter
Sun Oct 28, 2007 7:41 pm
But Turbo's are so.... russian.
baboon5151
Sun Oct 28, 2007 8:27 pm
if you go for air filter its best just to leave standard box on but put a k&n pannel filter in.i tried induction kit found i lost power so changed back & fitted pannel filter much better.
mick_318is
Mon Oct 29, 2007 1:59 pm
First easy mod is the heater plate removal. You get some instant gains without having to spend any money. There are several threads on here even a technical article I seem to remember :D
This is next on my list when I get the time.
Mick
6-Shooter
Mon Oct 29, 2007 4:02 pm
mick_318is wrote:First easy mod is the heater plate removal. You get some instant gains without having to spend any money. There are several threads on here even a technical article I seem to remember :D
Mick
This sounds good and makes sense in theory so I'd try that for sure (think I will!).
The cone filters always confused me as you have channeled air into an enclosed space with the AFM box set-up versus a round cone thing that is just gathering whatever air manages to make it's way through the grille.
I wonder if an enlarge intake from the grille to the AFM would make a difference - like some massive duct tubing or something...
Made of carbon...
With 'CSL' written on it...
Rosc0PColtrane
Mon Oct 29, 2007 4:17 pm
How about an extra couple of cylinders???? :twisted:
jam172
Mon Oct 29, 2007 4:25 pm
Nice one Nathan but i think you'll find that your 6 cylinder 320i only produces 124BHP in standard form :wink:
Sorry mate, us 318is boys need to stick together :)
An E30 touring, two E28 M5's and an E28 528i.
6-Shooter
Wed Oct 31, 2007 8:34 am
jam172 wrote:Nice one Nathan but i think you'll find that your 6 cylinder 320i only produces 124BHP in standard form :wink:
PEEEEEEEEEEEEEEWNED!
Rosc0PColtrane
Wed Oct 31, 2007 8:54 am
:moon: Irrelivant!!!
6-Shooter
Wed Oct 31, 2007 9:01 am
Irrelevant how?
You got revealed! All that 6-Cyclinder noise you make and you're rocking a 320i?!
Shit, you need 2 LESS cylinders dog to play with the big guys.
jam172
Wed Oct 31, 2007 11:38 am
:D LOL, thought that might rattle your cage Nath, no offence intended mate and my IS engine is sat in my 316i Touring, so i shouldn't really be quoting figures anyway.
That said the M42 is a very understated engine and crys out for a few mods, i have just fitted the Zone chip to my ECU and there seems to be more usable power through the rev range, i wouldn't say it produces anymore power though.
In my opinion, i would try one thing at a time, next on the list for me would be the BBTB, i have heard mixed reviews on the benefits in removing the heater plate, but it seems to be a job to be done at the same time as the BBTB.
I would say that before you attempt any mods, make sure the engine is running at it's best in standard form first, check the engine breather hoses are not split (under the inlet manifold, mine were) and clean out the throttle body and remove and clean the Idle control valve (use brake/clutch cleaner or carb cleaner), new plugs, new/clean airfilter and oil and filter change.
Last and not least, the M42 is still giving around 34MPG, how's your MPG Nath :wink: :roll:
6-Shooter
Wed Oct 31, 2007 11:45 am
PETROL PWNED!
dannyboy759
Wed Oct 31, 2007 12:12 pm
buzzy little M42 out great big heavy M20 in!! :D
Expensive Twin cam wrongness!!!
jam172
Wed Oct 31, 2007 12:25 pm
:roll: Why expensive?
The M42 is cheap to run, cheap to maintain, duplex bullet proof timing chain, don't see your point really?
The M20 320i has the heavy fuel consumption of the 325i without the power? Each to their own, i have two E28's one is an M5 (now that is expensive to maintain) and a lightly modified 528i M30, it's thirsty but has the power to go with it.
Please explain?
Rosc0PColtrane
Wed Oct 31, 2007 2:11 pm
I don't need to drive fast as my car doesn't make an embarrasing noise akin to a copy typist on Amphetamines!!!
Expense is Timing chain and tensioner change opposed to a cambelt on a m20.
(Jamie, I couldn't give a rats a$$ about my 2ltr, it's in a cab so sooper heavy and sooper slow, FTW, I like winding up the m42 crowd who seem to think the i.s was forged by the hands of God himself and assembled by superman. Why just the other week an i.s owner claimed to nail a scooby through the twisties!!)
My b20 is irrelevant as I said 2 extra cylinders, not a b20 would be a modification for the m42. Next you'll be telling me it's a 'baby M3'. A b25 is an improvement, an m50 is an improvement ad inifinitum.
Stop willy waving about you very impressive fleet of chrome turds and antiquated hulks of tin worm food......
(I'm just jealous really!!!!!) winkeye
tim_s
Wed Oct 31, 2007 2:59 pm
And there was me expecting to find a thread on engine mods for a 318is.
An 'improvement' is adding a belt driven 70s belt-driven 2v engine that typically make an extra 30hp at the wheels (if you're lucky) for an extra 700cc, 2 cylinders and extra weight forward of the front axle? fantastic. and original.
oh and ftw = for the win, fwiw = for what its worth
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
march109
Wed Oct 31, 2007 3:05 pm
wasn't the m42 forged from adamantium? and instead of CO2 I heard its so good for the enviroment the only things it gives off out the tailpipe are butterflies, rays of sunshine and fluffy baby bunny wabbits.
Seriously I did own a 318is and a 325 sport at the same time, funnily enough in the same colour. Although the sport was faster, and easier to maintain on my driveway I didn't feel as confident throwing it into corners as I did in the 318is. The 318is also did just sip on the old fuel unlike the sport which gulped no matter how much you nursed it.
Ziggy
Wed Oct 31, 2007 3:16 pm
Why put a bigger engine in an iS? Kinda defeats the whole point of the car, whether you like it or not...
E30Mark had a firebreathingnutterb*****d chip in his at one point, & aparrently it made a huge difference, if you can find one...
jam172
Wed Oct 31, 2007 3:58 pm
Rosc0PColtrane wrote:I don't need to drive fast as my car doesn't make an embarrasing noise akin to a copy typist on Amphetamines!!!
Nathan as i am sure my wife would confirm, i never willy wave, as even close up you would see nothing waving :o:
If you mean boasting, then yes i know you're jealous :wink:
Rosc0PColtrane
Wed Oct 31, 2007 4:46 pm
Yes I meant boasting!!!
On the other point, it's not the size of the boat, it's the motion in the ocean that counts!!!
Rosc0PColtrane
Wed Oct 31, 2007 4:47 pm
march109 wrote:wasn't the m42 forged from adamantium? and instead of CO2 I heard its so good for the enviroment the only things it gives off out the tailpipe are butterflies, rays of sunshine and fluffy baby bunny wabbits.
New thread in the Chuck Norris style idea forming.... Will use this to start it..... [twisted]
schuey
Wed Oct 31, 2007 6:31 pm
I have just sold my 325i so I can return to the IS crew! The six pots are sh1te. Anyway back on topic,the heater plate removal is a great mod,only takes 10 mins and makes a noticable difference! :cool:
318 IS. Sold.
6-Shooter
Wed Oct 31, 2007 8:10 pm
The 318iS is the best all round E30 - everyone knows who I am.
