zone demister switches
Cloggy Saint
Davenotouring
It was Ian332iSport.
I'm guessing they're still doing them.
I had mine done today. Just tried it out tonight! It's great!!!
Every little helps....
BMW 328i Cab - Daily Slag
Cloggy Saint
Cloggy Saint
Davenotouring
It's a great modification mate!
It's especially sweet on the Touring because then at night you have:
Red - Hazard Switch
Yellow (Amber!) - Heated Rear Window
Green - Wipers
Cool!
This is if you rearrange the wiper to the right and HRW to the middle!
Red - Hazard Switch
Green - Wipers
Cool!
Cloggy Saint
Davenotouring
Maybe it can?
A/C switch?!
Only ever seen one!
A/C switch?!
Only ever seen one!
Cloggy Saint
ian332isport
That's actually on my list of 'thing to do'datourer wrote:Ian, what do you think??datourer wrote:It would be nice if the same trick could be used on the AC switches...
I am in the process of fitting A/C into my car, so will be looking into this. It might be harder to do on the A/C switch though, as it's actually two switches in one housing, so may not have any extra pins for me to work with. I guess it may be possible to run a couple of small wires in through the side of the switch, and have most of the extra bits on the outside, but until I pull my switch apart, I won't know for sure.
My car is in the Bodyshop for several weeks, so I won't be able to look for a while, but I'll let you know if I get it done.
Cheers,
Ian.
schmick325
ill be up for an illuminated A/C switch!!
Car will look like an aircraft cockpit!
andyp
- True Old Skooler
mine light up on all my cars already, do they not come like this then ?
cros
Mabye a touring wash/wipe switch could be used to make a light up A/C one?
