Meguuiars quick clay
Where did you get it from dude ?Simon13 wrote:Got this stuff the other day
And it does exactly what it says on the tin Ronsil stylee
Sh!t hot paint work smooth as a babys arse!
not bad for 11 quid
Mark.
Davenotouring
Simon is watching the OC....
You can get it from here..
http://www.speeding.co.uk/acatalog/Meguiars_.html
I've had good service from them before when ordering products. Careful you don't end up ordering the whole shop, which is all too easy.
I bought some Gold Class Shampoo recently which is pretty good and foamy
BMW 328i Cab - Daily Slag
E30Mark
I got mine from Halfrauds...
PM for details
PM for details
Davenotouring
That could be easierE30Mark wrote:I got mine from Halfrauds...
that stuff is the dogs danglies!!
I have got most of the meguiars range! (perk of working in a motor factors) and i use the nxt car wash, then the clay, and polish using the nxt tech wax! and she comes up a treat!
then finish off with the fancy bits like trim using nxt trim detailer!
just make sure you do a panel at atime keeping the panel well lubed
and turn your clay as you see it build up with shat
billgatese30
i don't think so si, you jsut keep playing with the lump of clay, as you would plasticine or blutak, untill there isn't a clean face/side left to , at this point you throw it away and use another bar.
hth
hth
billgatese30
good, when it gets a bit dirt on it, knead it like a ball of dough in your hands till you get another clean bit to use on the car, its when there is no clean bits left when you keep on kneading it that you throw it away and replace it.
is this major ball ache to do??
i really want to get mine clean for the swansea show, got the 3 step meguires but still leaves swirl marks etc
[img]http://
