Power Steering Fluid- Which type and where to buy.
According to the Haynes Manual, power steering fluid should be Dexron II type. a) Is this the best type?, b) Where will be the cheapest place to buy? (Halfords, BMW pats dept. Or a local car parts shop)
Ant
- Retired Team Member
- Contact:
local parts store
dont just top it up, buy 2 litres and replace all of it, worth the extra effort
Email FTW
ian332isport
- Contact:
Dexron II or Dexron III will be fine. I usually get mine from Halfords or a local factors.
Ian.
Ian.
ian332isport
- Contact:
Pull one of the pipes off is about the only way really. Once its basically drained, wind the steering backwards and forwards to pump out as much of the old fluid from the rack as you can.thedingbat wrote:How do you drain the system to refill?
Also make sure you use new crush washers on any pipe joints you undo.
Ian.
http://www.e30zone.net/modules.php?name ... echnps.htmthedingbat wrote:How do you drain the system to refill?
Breaking 325i Touring
- Brianmoooore
Once you've flushed it, run it for five minutes, move the steering from lock to lock a few times, switch off, and do it all again.
Keep doing it until the fluid stays a nice red colour.
