1.8is engine spec..
Hath
Tue Jun 19, 2007 4:30 pm
i ahve got one of these engines... goes in on sunday along wiht manula covnersion..
can someone give me a little more spec on the engine.. power.. torque.. best enigne modfication to look at getting..
thank you please
less2303
Tue Jun 19, 2007 4:58 pm
Try here:
http://www.esatclear.ie/~bpurcell/
Should tell you all you want to know, and more!
Hath
Tue Jun 19, 2007 5:02 pm
thanks mate :$
Loony
Tue Jun 19, 2007 8:43 pm
While it is out it may well be worth replacing the sump gaskets and some of the other engine gaskets.Also take the rocker cover off and check and tighten the bolts that hold your pullys on.mine came undone and one came out which could have destroyed the engine.It may also be a good time to replace the rubber fuel lines near to the throttle area.
