Right going to be installing the is suspension and brakes next weekend, can any of you think of anything else i may have forgotten?
Parts:
M3 excentric bushes
E46ci top mounts
Self locking nuts
brake hoses
think i need a new just boot for on of the control arm knuckles
springs? Karen have you still got them springs?
ATE racing blue brake fluid, Does anyone know where I can get this in london, or enroute to Nrth wales ie B'ham etc etc
Tools
Trolley jack, stands etc etc
Impact driver bzzzzzzzh!
spring compressor
monkey wrench
puller (maybe)
ball joint fork
Any thing else? TIA
What have i forgotten? is brakes+suspension install
Gwynleym10
Karan
thats all really...
to get the rear trailing arms off on the drivers side u will need to remove the rubber filler hose that gpes into the fuel tank... as u wont be able to remove the bolt otherwise....
u have pm regarding springs
Gwynleym10
Might be time to get a new one of them, cause its probably the original and no doubt perish in my hands when i take it off!
Thanks for the P.M will call you at some point
Martinaston
Sounds to me like someone's had it off before and put the bolt in the wrong side?
Karan
no mate.... trust me the bolts go from the centre out always... as it would be immpossible to remove the bolt if it was the other way round as it would touch the chassis of the car...Martinaston wrote:Sounds to me like someone's had it off before and put the bolt in the wrong side?
Demlotcrew
yup i back karan up on that.
Andrew
Andrew
Andy335Touring
Gwynleym10
mmm nice, do you recon a 1litre is enough? how much does the brake system take? allowing for minor spilages etcI've got a liter of Castrol SRF if you want ?
Nottingham ain't far of the the track either...How many dollars do you want?...P.M me!
Thanks!
Andy335Touring
YGM
