got an is non abs went to bmw for some brake lines (front arch from brake to near strut). bmw want £33.00 . Zone shop want £53.00 for goodridge hoses. Are these the same bit of hose that I would have asked for from bmw? Has anyone got them?
Cheers sean
brakes hoses
No mate, bmw hoses are rubber, goodridge ones are braided steel and offer better performance. You want the 6 line kit as your 318is will have rear discs. The following link is where I got mine from....
http://cgi.ebay.co.uk/BMW-M3-E30-6-Line ... dZViewItem
I was thinking off taking the rear subframe off and giving it A good old clean up. See you lads do it with ease. Tried this before thinking ill make a few quid breaking a 325. Cut brake lines, hand brake cable, remove diff mount thing, shocks, grinded off allen heads on side but was left with this stud and look liked thier was A nut on the end but no joy.Was banging the F**k out of the disc up and down on each side hoping it would loosen but no good.
What did I do wrong? any ideas?
- klu99apm
Sounds like when you tried to take the rear subframe off before you got as far as where the main axle bushes get seized in their mounting under the rear seats.
Once you've undone the big nuts (22mm) under the bushes, and released the holder by grinding off the hex bolts you should be able to remove the bolt that goes through them and then with a bar or something up the bolt hole wiggle until they free up. I've done this this week and asked similar questions
http://www.e30zone.net/modules.php?name ... ic&t=68515
gareth
cheaper here...
http://www.rallydesign.co.uk/catalog/pr ... cts_id=360
cheaper still if you don't want branded goodridge ones!
