BMW E30 NIGGLIES LIST: POST YOUR COMMENTS
anton
Fri Jun 01, 2007 8:37 pm
Moderators, make this sticky for like ever!!! please
the e30 nigglies to look out for or to fix when u get a e30 are one or more of the following:
1) check control light
2) door lock can get stiff and temporarily seize..lube required
3) windows can start moving slower in cold conditions(electric) once again
lube required
4) stuttering wipers - remove old rock hard grease from motor and regrease and clean.. fixes it
5) lil globes on electric window buttons
5) corroded door switch terminals can cause havoc with alarms!!!
oxidised more than corroded..
6) almost flat door rubbers
7) almost flat boot rubber
8) tailight gasket flat from age
9) rubbers from 6,7,8 are shot from age. needs replacing
10) little fan behind OBC gets noisy..i replace mine.
CALLING ALL E30 fans to add your NIGGLIES to this list.
lets make a list of all these things for first time buyers..
im finding my (ive had it for 8months) e30 325i is a lovely car but there are all sorts of nigglies that need attending too..i suppose its the age.. but the foundations of the car are good. just the small things.. that keep popping up..
slinky2000
Location: Ireland - North(Portadown) and South (Limerick)
Fri Jun 01, 2007 8:42 pm
what about,
erratic temp guage (tighten the brass nut behind it)
headlamp wash/wipes do not work
non working sunroof
Gortour
How long do you want this thread to be?
Central locking stops working - search for red / black wire
M20 heads crack
M42 Profile gaskets leak
Batteries die in the service indicator pcb
Bulbs go in the OBC
We could go on all night...
Great idea though... :D
Fri Jun 01, 2007 8:44 pm
I'd add blowing dashboard bulbs, gearchange bushes wearing, spongy brake actuation, low-geared steering, sticking headlamp wash/wipers, driver's seat wear and bootlid toolkits missing their tools/gloveboxes missing their torches :x
Great cars though (have owned 3).
Gortour
Fri Jun 01, 2007 8:47 pm
Headlight adjusters always seize
Rust in the rear arches, sills etc...
anton
Fri Jun 01, 2007 9:20 pm
seriously... lets make a list... but lets define.. this is not a list of e30 weaknesses...
but simply things that need attending because of the cars age!!
for instance... the m20 heads cracking... please correct me if im wrong.. but as far as i know..
when changing the water/radiator water..there is actually a bleeder valve that has to be used to get rid of air.
as far as i know the heads cracking is caused by air bubbles in the system. and the standard bmw procedure is to follow the strict bleeding procedure.. lots of people dont... i presume... that perhaps the air bubbles causes inefficient cooling...and when the bubble pops there is a suddent change in temperature.. i.e hot head..and suddently cold water goes onto it..just a though.........????
im probably plucking at straws.... please people..dont ask me what ive been smoking..simple correct above if needed..
:mad:
ciao
Anton
Ritchie
Fri Jun 01, 2007 9:28 pm
[quote10) little fan behind OBC gets noisy..i replace mine.[/quote]
I didnt realise there was such a thing.
'99 E39 M5
'93 E34 525ix Touring
Fri Jun 01, 2007 9:57 pm
Ritchie wrote:
10 wrote: little fan behind OBC gets noisy..i replace mine.
I'm a little confused by this one as well!
SPADGE
Fri Jun 01, 2007 10:01 pm
I suspect he means the heater fan guys :D
Fri Jun 01, 2007 10:07 pm
anton wrote: CALLING ALL E30 fans to add your NIGGLIES to this list.
I can see this turning into a 64 page thread :)
maxfield
Fri Jun 01, 2007 10:08 pm
Make that 128 :)
Ritchie
Fri Jun 01, 2007 10:36 pm
SPADGE wrote:
Brianmoooore wrote:
Ritchie wrote: I didnt realise there was such a thing.
I see! yeah, mine just stopped working on the first setting. :roll:
'99 E39 M5
munky30
100% Pure Council
Fri Jun 01, 2007 10:40 pm
I think there's already a list of things that commonly go wrong with e30's...
It has 15000 odd entries and is called 'Technical help'
Fri Jun 01, 2007 10:43 pm
Ritchie wrote:I see! yeah, mine just stopped working on the first setting. :roll:
Well get it lubricated and up and working again, ASAP, while it's still salvageable!
oakey
Fri Jun 01, 2007 10:46 pm
munky30 wrote:I think there's already a list of things that commonly go wrong with e30's...
lol. true
Fri Jun 01, 2007 10:48 pm
1] 20 year old rubber.
2] lack of copper grease.
3] lack of silicon grease.
4] previous muppetry.
The above covers most things.
oakey
Fri Jun 01, 2007 10:50 pm
Brianmoooore wrote:4] previous muppetry.
^ the most common e30 problem in my experience. :x
Ritchie
Fri Jun 01, 2007 10:52 pm
Will do Brian. :wink:
'99 E39 M5
munky30
100% Pure Council
Fri Jun 01, 2007 10:54 pm
:eek: My heater stopped working on settings 1 and 2 the other day.... What do I need to lubricate??! 8O
Fri Jun 01, 2007 10:59 pm
munky30 wrote::eek: My heater stopped working on settings 1 and 2 the other day.... What do I need to lubricate??! 8O
The motor bearings. Need to take it out to do it properly with thin 3 in 1 type oil.
Could also just be a failing resistor section of course, but when speed 1 fails, followed later by speed 2, it's usually the bearings tightening up.
munky30
100% Pure Council
Fri Jun 01, 2007 11:03 pm
I never tried 1 or 2... it's always on 4 to stop my car overheating :o: (which it now looks like it wasnt actually doing :roll: )
SOrry for the brief hijack... but (bearing in mind my other worries at the moment and its summer so heaters aren't high on my list) would you advise I do it, or just let it die and replace it?
hammoj28
Sat Jun 02, 2007 12:31 am
Hmmmm, where do i start!
Scratches that i have no idea where they have appeared form.
Dents i notice
Has a tiny bubble on the drivers wing and sunroof
Standard ride height is pissing me off, need to get it lowered,
M42 sowing machine noise is a bit annoying
Stone chips
Getting quite annoyed with it at the mo but i still love it!lol :D
24v tech2
griff87
Sat Jun 02, 2007 12:42 am
Idle valve
Central locking
Hoses
Rust
Noise from the prop :?
Martinaston
Sat Jun 02, 2007 12:53 am
Lack of rust inhibitor (antifreeze) in the cooling system.
Knakerd bushes.
There is NO nucleus.
HairyScreech
Sat Jun 02, 2007 2:03 am
noisy injectors.
i think we should put a poll up with all of the common problems on it and aeverone can click the ones they have. give a good idea of how many people have each of the usual ones.
reggid
Sat Jun 02, 2007 3:49 am
rusted sunroof
oakey
Sat Jun 02, 2007 11:53 am
Seatbelts not retracting properly,
Blocked washers
Rosc0PColtrane
Sat Jun 02, 2007 2:41 pm
The stupid piece of over engineer white plastic to regulate flow to your washers.
cossiecrew
Sat Jun 02, 2007 3:15 pm
sunroof panel rusting and tourer hatch under rubber
stonesie
Sat Jun 02, 2007 3:26 pm
M20 Throttle position switch and blue temp sensor :wink:
Gortour
Sat Jun 02, 2007 5:34 pm
Touring rear washers - Either blocked, not working or p*ssing water into the boot)
...though mine seem OK at the moment...
(famous last words...)
gra325i
Sat Jun 02, 2007 5:45 pm
cant believe no-ones mentioned the brake light switch at the pedal....bain of my life :x
JohnnyThunders
Sat Jun 02, 2007 7:36 pm
Albatross nesting in the backbox. Really annoying one.
anton
Sat Jun 02, 2007 9:51 pm
to all those that were confused by:
little fan behind OBC gets noisy..i replace mine. i wasnt smoking something.
just infront of the OBC there is a little "vent" like thingy..
behind this.. i.e part of the OBC(onboard computer) there is a small 30mmx30mm fan. this fan gets noisy and buzzes. i think the fan is used by the obc to draw air for temperature display.
emphasis on "i think".
btw... has anyone here ever overhauled/repair their heater valves? my heater works intermittantly... sticky valve..
what are the steps in doing the repair? where physically are the valves? is it a job for me old favourite 600grit sandpaper?
ciao
Anton
Frenchy
Sat Jun 02, 2007 10:01 pm
My temp needle has a bad do flicking about now and then but then sorting itself after a few seconds will take a look at that when i strip the dash out to fit my 6 button OBC kit(which has been sitting in the garage for months) winkeye
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......;-)
