So going to find out what its at before i make the rear axle so i have a starting point, so come on whos going to be closest,
CAMBER :
TOE :
here is a few picture for you to guess from.
he he he
it is low and traction is very little at the rear
Unless you have custome frame or arms installed, the natural bump steer will add camber and toe... if you've got no toe you've done something to get rid of it, or more likey its very little and cant see it, but its there.munky30 wrote:Mine is on a 100/85 drop.
It used to be on cut springs, now on custom wound ones.
I have 15's.
I have no toe in.
Andy335Touring wrote:Make sure you lube those spax adjusters well or they will seize like mine![]()
superclarkey wrote:Andy335Touring wrote:Make sure you lube those spax adjusters well or they will seize like mine![]()
already on it... spray grease is a wonderful thing
munky30 wrote:Ahhh that does look a lot better. Still a bit much though... I cant see why lowering it would do that, though it possibly has more to do with the powerflex bits.
This is the only pic of mine I can find that shows how straight it is.
to compare.munky30 wrote:
Yeah the arch to wheel gap looks a touch smaller on yours. But With the lower profile tyres I'd say the underside of mine may be a bit lower...superclarkey wrote: I think mine looks a tad lower then yours... when it was on a 60mm normaly kit the wheels were half as bad as they are now.
So that would explain it.
Sounds idealsuperclarkey wrote: defo worth the money, but, i noticed on stock shocks the grip was amazing, even in the wet, as it bite nice, now with stiff shocks there is no traction and it just drifts everywere.
Eh ?????superclarkey wrote:i basicly got the stock springs and cut many coils off front and rear, to get the same drop, less coils = stiffer spring..
How do you remove the "Progressiveness" ?and i removed all the progressive ness out of them...
Then fitted 40mm kit from spax, cut the progressivenes out of them too,, amazing on stock shocks,
that dont look right at allsuperclarkey wrote:
