Offside front (floor) suspension component mounting excessively corroded.
N/S Front coil spring incomplete **DANGEROUS**
O/S Front coil spring incomplete **DANGEROUS**
N/S Rear coil spring incomplete ** DANGEROUS**
O/S Rear coil spring incomplete **DANGEROUS** Old news, time to re-fit those standard springs... temporarily.
N/S Front (link bar) anti roll bar rubber bush deteriorated.
O/S Front (link bar) anti roll bar rubber bush deteriorated.
N/S front position lamp not in good working order.
O/S front position lamp not in good working order. Do they mean sidelights?
O/S front direction indicator not working.
N/S Headlamp aim too low.
O/S (and pattern) headlamp aim too low. pattern??
N/S and O/S wiper blade deteriorated.
O/S rear passenger seat cannot be secured in upright position.
Exhaust system has a major leak of exhaust gases.
Exhaust system has a part missing.
Exhaust system noise is clearly in excess of that emitted by a similar vehicle fitted with a standard silencer in average condition. Bugger. there goes my 'weld some pipe onto the mid section if it passes emissions plan.
Nearside (sill) seatbelt anchorage is excessively corroded.
Advisory items:
6 Cylinder engine is fitted.
Emissions:
CO2 %: 1.021 (max 3.5)
HC ppm vol: 183 (max 1200)not bloody bad considering it only has half an exhaust!!
so.....it failed...
For everything except the exhaust, suspension and rear seat they quoted me 175 which isnt too bad I guess.
edit>see last page for update
