m3 5 stud conversion
E3OBM
Fri Mar 30, 2007 6:22 pm
hi, i have done a 5 stud conversion on my 325i cab using e36 bits but they come out an inch wider.
if i use the e30 me setup will it be the same as coming out an inch or will it sit just like my normal 4 stud fit.
thanks
Ray
maxfield
Fri Mar 30, 2007 9:11 pm
Will sit like normal E30 setup.
Kos
Fri Mar 30, 2007 9:16 pm
maxfield wrote:Will sit like normal E30 setup.
M3's got a wider track i belive
www.pukardesigns.com
IG Pukar.Designs
maxfield
Fri Mar 30, 2007 9:18 pm
You maybe right but i can't see it sitting much further out then a normal E30 setup.
Altho might of been a misuderstanding due to wider arches :?
chicozoo17
Fri Mar 30, 2007 11:56 pm
can you put up some pics of how it looks?
Sat Mar 31, 2007 7:55 am
e36 wheels are a high offset, obviously e30 m3 is low
m3's only have an extra few mm track over a 4 lug
E3OBM
Sat Mar 31, 2007 9:32 am
chicozoo17 wrote:can you put up some pics of how it looks?
will do later.
so is the m3 conversion the best one to do, it will only stick out a few mm.
Sat Mar 31, 2007 4:52 pm
if you stick with e36/e46 rims the wheels will sit exactly the same as an m3 conversion
