Prices and info for the BMW E30 window kits are below,
BMW E30 + E30 M3 window kit (Meets or exceeds current MSA / FIA specifications)
* Kit contains all windows except for the front screen
4mm clear FLEXIGLASS @ £180.00 + VAT
4mm clear POLYCARBONATE @ £200.00 + VAT
4mm bronze or grey POLYCARBONATE @ £200.00 + VAT
4mm clear LEXAN MARGARD POLYCARBONATE @ £380.00 +VAT
5mm clear LEXAN MARGARD thermoformed front screen @ £270.00 + VAT
Slider Kits @ £23.50 per door and are fully installed, these measure 210 x 210 mm as std
*FLEXIGLASS is a DOT approved safety plastic, available only from Plastics 4 Performance and we consider this to be a good all round material for all forms of motorsport except rallycross
*POLYCARBONATE - We only use genuine MAKROLON or LEXAN UV protected exterior grade materials which have DOT, ANSI and ISO approvals for use as safety plastic and all our polycarbonate kits are 100% polycarbonate, we do not substitute for lower grade materials in thermoformed screens
*LEXAN MARGARD POLYCARBONATE -Abarasion resistant polycarbonate kits, the material has a special hard silicon coating applied to both surfaces to combat scratching, Carries all safety certificates needed and we are proud to say that Plastics 4 Performance are the only suppliers of moulded hardcoat screens in the UK
Paul Davenport
Unit 10 locke Ind Est
Emmett street
Horwich
Lancashire
BL6 7PN
UK Telephone / fax 01204 696 609
International Telephone / fax +44 1204 696 609
Mobile 07890 513 398
eMail
info@plastics4performance.co.uk
Web
www.plastics4performance.co.uk
_________________
