Photo Required Please
E30Adam
Post Sun Jan 16, 2005 11:49 pm
Can anyone with a centre seatbelt in the rear please take a photo of the part that you clip into the errr bit that you clip it into lol
I know what I mean... it's the bit on the end of the belt and not the bit with the button.
Ziggy
Post Sun Jan 16, 2005 11:53 pm
gimme a min :thumb:
Ziggy
Post Mon Jan 17, 2005 12:01 am
This bit?
E30Adam
Post Mon Jan 17, 2005 12:30 am
Cheers fella, that's the bit. Does it clip into the bit it's meant to clip into??
You see.. mine looks identical to that but the little plastic bit in the middle of it prevents it from clipping in. Is your centre clippy-in bit different to the other 2 or the same. All 3 of mine in the back are the same but my 2 outer belts don't have that little plastic knobble bit!!
Ziggy
Post Mon Jan 17, 2005 12:46 am
Erm...!
The other 2 belts don't have that "knobble" - I thought maybe it was to help it clip in to the bit on the parcel shelf, but it doesn't appear to do much... I don't use that anyway - prefer to just hide the belt under the armrest.
The belt clips into either of the "clippy-bit-with-the-red-button"s quite happily, & they all appear to be the same!
E30Adam
Post Mon Jan 17, 2005 12:52 am
That is very very odd. I think you're right about the platic bit helping it to clip into the parcel shelf but it definately stops it from clipping into the bit with the button (what do you call that) and all 3 of mine are also the same... I think I'l sleep on it :sleep:
Ziggy
Post Mon Jan 17, 2005 5:07 pm
Very wierd... maybe you've got new style clippy bits & old style belts for some bizarre reason?! Don't even know if they changed! I'll take a pic of my clippy bit if you want...
E30Adam
Post Mon Jan 17, 2005 5:08 pm
Yeah go on, wouldn't hurt to compare
SCOTT325SE
Post Tue Jan 18, 2005 3:52 pm
may i suggest that you call the "clippy bit with the red button thingy" the seat belt "reciever?" It would save loads of typing and thats what i call it anyway..... much shorter than "the clippy bit that the belt clips into with the red button thingy"
E30Adam
Post Tue Jan 18, 2005 4:23 pm
"receiver"... yeah I like that... well done mate !
Paul325i
Post Tue Jan 18, 2005 4:35 pm
sounds like some moron has fitted an outer belt receiver into the centre.
E30Adam
Post Tue Jan 18, 2005 4:48 pm
Paul325i wrote:sounds like some moron has fitted an outer belt receiver into the centre.
They all look the same though, would the internals be different?
