Slightly Noisy diff on 320i Convertible E30
delphin
Post Sun Mar 11, 2007 7:42 pm
Hello .
I have been offered a replacement Diff off a broken 325i Convertible that's only done 50,000 miles, would this be identical to my old 320i Diff.
I'm hoping it's is a simple swap?
Please could you advise me.
Many thanks
handpaper
Post Sun Mar 11, 2007 11:08 pm
All you need to know is in this thread:
http://e30zone.co.uk/modules.php?name=F ... ic&t=47781
The diff will almost certainly have a different ratio (3.91:1 vs 4.1:1) and be a larger case size, however these do not present too much of a problem. The different (lower) ratio will give you a more relaxed drive and slightly better fuel economy (revs 5% lower for any given situation) and the larger case diff can be accommodated simply by adjusting the propshaft length.
I did this to my 320i purely to increase the top speed and make 4th a more useful gear - the car will still rev out in top (indicated 140 mph 8))
