Dear, Friend
Does all E30 engine will burn engine oil? because after I rebuilt my M40 engine. The Oil is still less, not a lot but it is about 5 milimeter below the mark in the dipstick after run about 4000 kilometer.
Is is normal?
Markus
Oil consumption on E30
markus_74
Most E30s hardly use any oil at all, but I wouldn't consider 5mm on the dipstick in 4000 Km to be excessive in any case.
markus_74
Thanks Brian
It is new engine because I just rebuilt it and I don't see any leak or smoke in the exhaust. Or is it cause of I made the honing in the cylinder wall? so the oil trap and burn in with fuel??
How many mm it will be normal in about 4000km?
maxfield
All engines lose a bit of oil when they are new or rebuilt.
Did you use cheap oil because that is recomended for the first 1k miles of an engine?
Why is that and why does it use oil for the first 1k or so?
markus_74
Dear, Max
No I always, I use Mobil 1 semi synthetic 10-40. For first 1000km and then replace with mobil 1 again and know it has reach 4000km. I'm afraid cheap oil will produce sludge in my HVA.
