LSD Tests
No not drugs !!! flowers attcking you and shit.......... took my wheels off to be taken for a refurb today and span the offside rear, nearside rear was stationary i beleive standard diff opposite wheel would turn in the opposite direction.
Your assistance please.
Cheers.
Cheers.
Alpina B3 3.3 Santorini Blue,White Buffalo hide with Blue Piping,Black Shadowline. No 242.
318 iS Diamond Schwarz.
Porsche 944 Turbo S,Special Order Black,Very Limited Numbers and Very Quick......
Cheers EKO is mine fooked then as no movement on the opposite wheel ???
My 320i's open diff (3.64:1) is like this too - no movement on t'other wheel. Still works OK
billgatese30
when both wheels are in the air, then an open diff will rotate the wheels in diferent directions, an LSD ewill both spin the same direction
when only one wheel is in the air, open diff will allow wheel to spin, LSD will not allow single wheel to spin
OllieB
- Contact:
Pull over on a grass verge (muddier and boggier the better) so both nearside wheels are on the grass, then do a fast start. If you don't get anywhere very quickly but the revs are high, then you nearside wheel is spinning and you don't have an LSD.
I'm too scared to drift properly......
Snoops,
Nee wheels their away getting re-furb!
& you get stuck in the shitOllieB wrote:Pull over on a grass verge (muddier and boggier the better) so both nearside wheels are on the grass, then do a fast start. If you don't get anywhere very quickly but the revs are high, then you nearside wheel is spinning and you don't have an LSD.
A limited slip does allow one wheel to spin on it's own, just transfers a %power to the non spinning wheel. Otherwise it would be a locked diffbillgatese30 wrote: when only one wheel is in the air, open diff will allow wheel to spin, LSD will not allow single wheel to spin
jaistanley
Jack the car up, put in gear and re-try.
If it is hard to turn the wheel but the other stays stationary or rotates in same direction you have an LSD.
Rotating opposite (easily) is an open diff.
Jai
Jai
Ant
- Retired Team Member
- Contact:
If the diff is an LSD, jack up one rear, leave out of gear, take the H/brake off and see if you can rotate the wheel in the air, no spin= LSD, spin = open/fubar LSD
you could work out the torque required to turn the wheel, so 170 lbs/ft x 25%= lsd slippage amount.
Maths are sound-ish
Maths are sound-ish
Email FTW
billgatese30
yes, but just trying to spin it by hand is quite difficultRB5_245 wrote:A limited slip does allow one wheel to spin on it's own, just transfers a %power to the non spinning wheel. Otherwise it would be a locked diffbillgatese30 wrote: when only one wheel is in the air, open diff will allow wheel to spin, LSD will not allow single wheel to spin
i was trying to explain it as simple as possible, otherwise it may have seemed to be confusing to those who are not mechaincally minded enough to realise that it allows a 25% lock up (assuming its a standard sport diff in good nick)
I believe this is wrong. I had my old car up in the air with one wheel down and put it in first with the wheel spinning so i could take the burr off the discs.billgatese30 wrote:when both wheels are in the air, then an open diff will rotate the wheels in diferent directions, an LSD ewill both spin the same direction
kam-325i
- Contact:
Driveshaft dragging on exhaust ? Dose the same on mine.Frenchy wrote:span the offside rear, nearside rear was stationary.
