Is it legal....
Post Mon Feb 19, 2007 1:42 pm
Can anyone tell me, is your car still legal and roadworthy if you take the whole dash out still leaving the clocks. Also taking the back seats out, you are left with a metal panel as if the seats we're still there and a metal parcel shelf. Those 2 panels, are they but of the structual strength of the car or not. They don't seem very strong and are not heavily welded, i was just wondering. I hope that makes sense ,thanks
Post Mon Feb 19, 2007 1:44 pm
it is legal, long as it is safe
panels contribute to the structural strength of the car however
ShineOn
Post Mon Feb 19, 2007 2:45 pm
As long as the car is working properly, then fine. If it could pass an MOT, you are ok.
smithy318i
Post Mon Feb 19, 2007 3:05 pm
Not having back seats isnt illegal.
As for the dashboard. I would suspect that you cant drive without it fitted. The reason being that the ECU is mounted to the dash just above your feet. If the dash is removed, you would need to tie it up with a piece of string.
But hey, as long as you don't get caught or crash into someone. Who gives? *
Disclaimer *I in no way condone driving a car without a dashboard.
maxfield
Post Mon Feb 19, 2007 3:08 pm
It is legal as long as you've got an indicator stalk foglights etc.
MOT don't test anything on the dash board.
Nothing a few cable ties can't sort out.
toby
Post Mon Feb 19, 2007 3:14 pm
MOT does include dashboard checks - e.g. fog light illumniation indication on the dash.
smithy318i
Post Mon Feb 19, 2007 3:20 pm
Why would you want to drive it without a dashboard fitted anyway?
maxfield
Post Mon Feb 19, 2007 3:22 pm
smithy318i wrote:Why would you want to drive it without a dashboard fitted anyway?
If it was a track car less weight
Post Mon Feb 19, 2007 4:40 pm
Thanks for the replies,
"As for the dashboard. I would suspect that you cant drive without it fitted. The reason being that the ECU is mounted to the dash just above your feet. If the dash is removed, you would need to tie it up with a piece of string"
i unbolted the ecu took the dash out and then bolted the ecu back where it came from, so that part is ok and every instrument that i should have is still there and working. Yeah i'm hoping to take the car on a track so it was a weight loss thing, the dash actually weighed alot more than i thought would.
Again thankyou
dobbie82
Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
Post Mon Feb 19, 2007 4:55 pm
:lol: I think you have taken the weight loss thing to a new level!! :clap:
I presume you have already removed everything else that isnt welded on?
e30 related ebay auctions + shop(MY Stuff for Sale), http://tinyurl.com/64aufr
My Feedback on the e30zone: http://tinyurl.com/dobbie82feedback
Post Mon Feb 19, 2007 5:51 pm
Yeah pretty much everything has came out thats not welded, it's very noisey inside now. I'll post some pics or something when my friend has sprayed it, he's a graffiti artist.
Morat
Post Mon Feb 19, 2007 5:52 pm
woah double negatives are bad, mkay?
that would be.
Not having back seats is legal
and
As for the dashboard, I suspect that you can only drive with it fitted.
not trying to be rude smithy, but I had to reread that bit a few times :)
Turbo-Brown
Boost Junkie
Post Mon Feb 19, 2007 7:48 pm
According to the SVA rules, you aren't allowed anything with a radius of less than 3mm (think it's 3mm) which is hard and could cause injury in the event of an accident. I'd guess that the dash moulding hides a multitude of sharp sins.
Having said that, if you're not planning to have the car SVA tested then I can't imagine anyone would pick you up on it.
Personally wouldn't want to have the sharp edges exposed (if there are any)
As for the panels under the seats, take this analogy for the body shell of the car:
Get a marg tub out of the fridge and remove the lid. Now grasp the tub with one hand at each end and twist. The tub exhibits minimal rigidity. Now, replace the lid and try to twist it again. It's resistance to twisting will have increased significantly, despite the lid (panel) being thin, flimsy and not particularly well attached.
miniblob
Post Tue Feb 20, 2007 9:30 am
You can definately drive and mot a car with no dash :wink:
All you need to have are switches for lights, horn, indicators, wipers, etc and dash clocks (warning lights and speedo are all you need). And obviousely strap/secure any cables, ecu's, etc.
327 Touring with bass!!!
