My Bad Luck
Crofty79
Post Sun Feb 18, 2007 10:49 am
Just wanted to winge a bit about my motor, i've got a 'F' reg 320i 4 door and funny enough it's due for an MOT next month.
I've got a bad leak on my power rack which i've know about for a while, just kept topping it up :o: . thought i got a barign from Ebay when a mate of mine bought a power rack for me.
When it came to the time to fit it there was a slight difference in the pipe work :cry: so that's still to do.
Then that week my rear passanger door started to play up :eek: thought my mum had broken it, but think it's the latch play up, As my wife can get it to close 8O but it takes me a while to get it closed.
Then my rev counter and mpg stopped working :cry: :cry: , and all this just before the MOT.
Funds are short so think i'm gonna have to keep it off the road untill i can get the bits done.
This is my first E30 and i love her to bits, so why is she treating me like this :( . Maybe she's in need of my hands tinkering with her as she feels left out, as i just got married in December.
Oh well such it life. Might find another E30 instead and use her for spares, but don't let her find out :wink: .
oakey
Post Sun Feb 18, 2007 11:06 am
rev counter could well be a fuse- happened to me a couple of times.
these cars can be a pain in the arse sometimes :x
as for the door issue, try slightly adjusting the position of the catch until it shuts ok.
ive got mot next month and my washer jets are buggered, ive got a wobbly back wheel which is causing a nasty noise when i brake and ive just realised that my mechanic has not put one of my shock inserts back on the car after changing the susp. :eek:
it'll all be sorted properly next week though :D
good luck bud
Post Sun Feb 18, 2007 11:16 am
When you changed the rack, did you thoroughly flush the rest of the system? If not, you know why the new one's failed! 20 years old isn't a bad life for a steering rack.
Rear door shouldn't need any adjustment to the catch plate. Check the rubber door seal is in place properly and not damaged, especially at the front. Any E30 door should shut with a satisfying "clunk" just as you should expect from a car of this quality.
Rev counter is irrelevant to the MOT.
Crofty79
Post Sun Feb 18, 2007 11:26 am
sorry ment to say that I didn't fit the rack in the end, looks like it might be a pre '88 as the pipes are in a different position to mine, need to see if i can make up new pipe or with gentle force bend them to fit.
Also my washers not working just drivers side and that's only on of the two on that side :x .
Taking a trip to the breakers yard and see what goodies i can scavenge winkeye
Cheers for the info though :D
