Does anyone know how to work out the maths behind the working out the top speed of the running gear setup???
E.G.
Tech2 325i (200hp) + Tech2 Standard Gearbox + LSD (3.64) = Top Speed???
Any help appreciated...
Diff Info...
clubfx2
Regards
Clyde
Go everywhere sideways...
Clyde
Theo
http://www.geocities.com/z_design_studio/
This is what you need, input the ratios for 1st-5th and set the final drive to 3.64 and you're away!
clubfx2
Thanks Theo...
Regards
Clyde
Clyde
Theo
No worries, you need to set the rev limiter as well, but that will depend on the chip you have in your car.
clubfx2
Its 6900 on the limiter.
Worked a charm.
Worked a charm.
Regards
Clyde
Clyde
stuartgallafant
i had to do this for real without using a website, the other day!
had to find out what speed i'd be travelling in a MINI if the engine was @ 2000rpm in second cear!!
i was confuzzled at first, but i happen to be fairly good at maths, so iworked it out... could of thought of better things do with my time tho!!!
