What would you recommend as I'm a total novice in the Beemer stakes?
What seats would you fit in your Tourer?
RapidE30
The Tourer I'm picking up at the weekend has a knackered drivers seat. They are cloth trim at the mo and I'd like to replace them with something else.
oze30
go for a sport seat. they've got more lateral support than the normal comfort seats. You could try to go for leather, but then your looking for some serious money
BadDave
Sports seats definately.
My 318 had the std "comfort" seats which were adequate but my 325 has recaro sports seats and there much better.you Can always get them re-trimmed to match your existing interior trim.
Material is available from BMW but will set you back more than £150 for enough to do both fronts
miniblob
Find out what pattern/colour trim it is and keep your eye open for a set of sports seats for sale!!!!
I have some blue cloth sports seats for sale if they happen to match the rest of your interior
327 Touring with bass!!!
Whatever type of seats you decide on, it's very easy to swap the backs from one seat to another, and passenger and driver's seats are interchangeable with very little work, so it's easy to assemble a decent set from a few damaged ones.
It's always a good idea to swap the backs of sports seats from side to side, as this will put the part of the side bolster which wears onto the inside, and put the unworn bolster outside where it will last for another fifteen years.
Folding passenger seat (from a 2 door) is always usefull on a tourer, for that occasional long load.
RapidE30
I've found a set from a 4 door, will these fit ok?
Cotty
- Hartge Crew
Yep the fronts should fit but obviously the rears wont (split folwing rear in a touring)RapidE30 wrote:I've found a set from a 4 door, will these fit ok?
