Technickle Knoledge needed???? M3 cams and fly wheel??
M3Jimbo
Post Tue Apr 05, 2005 10:54 pm
Ive just got a new fly wheel for the M3
Has any one drove a car with one fitted
It weighs 8lb compared to the standard 18lb
The engine has also got a set of shrick 284's
does any one konw what the rev limiter should be pushed up
to? its also got ARP rod bolts?
Thanks to adrian in newcastle who showed me what a never
been run Ԛ£13000 S14 lump looks like
Yummy!!!
Yes my misses is in bed under the fly wheel!!
And yes she can fucking stay there!!!! :wink:
Post Tue Apr 05, 2005 10:57 pm
:drool:
luuuurvely :cool:
driven a 2.0 16v corsa with a 4kg flywheel instead of a 10kg one and yummy throttle reponse is awesome
M3Jimbo
Post Tue Apr 05, 2005 11:12 pm
Im hoping it will rev up and down like an R1
brm brm brm :twisted:
Toby_Unna
Boost Junkie
Post Tue Apr 05, 2005 11:31 pm
it will be good.
when i was building my 335i i ran the engine in the car with just the automatic ring gear on the end of the crank (it's the same shape as a flywheel but its only purpose is to connect the starter to the crank, the torque convertor provides the flywheel effect)
only weighs about 1 or 2kg compared to 12kg for the manual flywheel, and that's 12 + whatever a 3.5 clutch weighs
and yeah it ran like a bloody bike, actually idled ok if a bit lumpy, but the throttle response was terrifying and the revs just died almost instantly. what a noise!
hence about half an hour sitting in the car just blipping the throttle :cool:
M3Jimbo
Post Tue Apr 05, 2005 11:35 pm
YAY YAY
that what i want!!!
Bin the fly wheel and weld the clutc to the crank!!!
Sorted!!!!
brm brm brm brm brm brm brm brm
Might suffer a bit up the hills though???
billgatese30
Post Tue Apr 05, 2005 11:45 pm
M3Jimbo wrote:Might suffer a bit up the hills though???
all the more reason to go faster :twisted: :twisted: :twisted:
Andy335Touring
Post Wed Apr 06, 2005 12:02 am
It depends at what revs peak power is and how quickly the power drops off from then on,normally you would have the limiter cut in 300-500rpm after peak power.
All of the above is assuming that your engine can take that sort of rev's safely ?
M3Jimbo
Post Wed Apr 06, 2005 12:18 am
Hopefully it should take a fair beating!
Phil Crouch From birds is building it!
Appaerntly he knows what hes doing!
Then a bloke called Jeff (started AMD) will be doing the remap
Cant wait
Maybe this time i will be able to run it in and drive it for a goo while before it goes bang 8O
Last time it only lasted from Gravesend kent to just north of the dartford tunnel!! :cry:
Be interesting to know what sort of red line to expect!
Im just getting over excited i havnt driven it in 7 months
and i had to look at it quite a bit!!
Can wait till i can do the lakeside run and ace's cafe and high beach and track days and take it to work with me and drive down to the south of spain in it with the bird!!!
Right im going to set up a tent out side the wo
rkshop!!!!
M3RAGS
Post Wed Apr 06, 2005 12:26 am
M3Jimbo wrote:Hopefully it should take a fair beating!
Cant wait
rkshop!!!!
phil crouch knows his sheeet! :cool:
Sideways S14
M3Jimbo
Post Wed Apr 06, 2005 7:07 pm
no one ever driven one with a simmilar set up? or no what rpm they can handle?
