Buying a Cab
Paul386
Post Sat Feb 10, 2007 10:13 am
Going to look at a Cabriolet tomorrow!!! :D :cool:
Ticks all the right boxes, has loads of Tax, MOT, history etc... but have never had one before... What should I be on the look out for when buying it?
DaveD
E30Zone Wiki Specialist
Post Sat Feb 10, 2007 11:04 am
try this ...plus the usual rust wear and tear etc.
http://www.e30ic.com/default.htm
JAFF
Post Sat Feb 10, 2007 11:10 am
dose sound good m8 ! :D
orangecurry
Post Sat Feb 10, 2007 11:17 am
What colour/engine is it? (it might be my old one :D )
Whereabouts in West Sussex?
Paul386
Post Sat Feb 10, 2007 11:29 am
cheers :D
its a 318 lux - blue with grey leather...
I'm in Haywards Heath in W.Sussex
orangecurry
Post Sat Feb 10, 2007 11:56 am
not mine :D
Make sure the rear-view mirror is on securely - not serious if it isn't, but it's a bargaining point.
Stick your fingers in the rear-wheel arches - make sure the gap between tyre and arch is the same on both sides of the car.
Look along the side of the car from the rear - make sure there are no ripples in the paint/metal directly ABOVE the rear wheel arch - if the cab has had a rear accident, they can twist slightly.
Check the hood operation - obvious one :D Is it a manual or powered hood?
Paul386
Post Sat Feb 10, 2007 12:01 pm
will do will do... is a powerhood...
DaveD
Post Sat Feb 10, 2007 12:09 pm
Paul386 wrote:will do will do... is a powerhood...
CHECK IT WORKS PROPERLY.....................really make sure ...no clicking noises and that it locks down ok ....Don't take their word...must be demonstrated.................... even ask to take the cover off and have a look at the motor...see the site i posted
orangecurry
Post Sat Feb 10, 2007 12:11 pm
Look at the mounting plate which sits under the rear 'flap'; a large rod comes off of this to operate the hood frame. You should try and see if this looks damaged...
If the hood doesn't work, it can cost a lot of money to fix if this rod has torn out of the drive plate on top of the motor, so again, your call.
If it's broken, I would walk away; my Calypso Red 318 cab was like that - you can live with it by raising/lowering the roof manually, but it was fixing the flap shut that I found annoying.
Of course if that is the only thing wrong, and the price is right, it's still a cab :D :D
Paul386
Post Sat Feb 10, 2007 12:32 pm
cheers people. will check the above!
Just got a really good insurance quote for it too... So fingers crossed!
Seller seems a really nice chap too, called me this morning saying he's had a few people say they'd come and give him the money today, but as I called first, he's keeping it for me to look at tomorrow. Not so good as haggling might be a no-go now, but he sounds like a genuine bloke, and has owned it for the past 6 years! It's a 2owner car too 8)
Paul386
Post Sat Feb 10, 2007 12:33 pm
where abouts in west sussex are you orangecurry?!
What do you drive?
orangecurry
Post Sat Feb 10, 2007 1:31 pm
he does sound like a good person to buy from.
I live north of Storrington, south of Coolham.
I drive an E30 cab of course :D
