H&R nightmare!
mac325i
Post Fri Feb 09, 2007 6:05 pm
Recently the handling has started to feel 'wooly'. I thought the arb links were the culprit, as i used the originals when fitting the H&R's -they looked sound.
I shat meself when i got under the car and saw this
I had read about this happening before fitting, but assumed i would be allright as i dont track my car.
Would it be possible to weld the tab back on then add re-inforcement, or is a new trailing arm in order?
I strongly advise anyone who has (or is thinking of fitting) a H&R arb kit to strengthen the arb link mounting tabs BEFORE this happens
J_Mac
Post Fri Feb 09, 2007 6:12 pm
nice :? thanks for the heads up mate, i would have thought a weld is ok and some renforcement to be on the safe side
mac325i
Post Fri Feb 09, 2007 7:12 pm
I think this should be in Tech help - Sorry!
Post Fri Feb 09, 2007 7:50 pm
be grateful the bar didn't rip itself off the car! They have been known to do this. Sorry to see!
I'd just swap trailing arms if it was me
mac325i
Post Fri Feb 09, 2007 11:21 pm
Simon13 wrote:be grateful the bar didn't rip itself off the car! They have been known to do this. Sorry to see!
I've got powerflex trailing arm bushes in atm, do you think these would swap over easy enough(been in less than a year). I dont want to have to buy a full set, just to use one side
If I hadn't replaced or upgraded every bush and suspension component(bar the springs) I'd be seriously considering a 5-stud conversion
If the tab was fabricated from thicker steel(which I have laying around), welded back on and some angle iron welded top and bottom as triangulation, this would surley be stronger than the Turner motorsport or ireland engineering soloutions and easily strong enough for my needs.
If I was to use another trailing arm, this would also need strengthening, meaning twice the work
Your opinions would be great guys!
