Independant BTB 6 branch results
reggid
Post Fri Feb 09, 2007 1:49 pm
The results are kW at the wheels not bhp which is more common around these parts it shows before and after with some tuning there were other exhaust changes such as high flow cats twin resonators and custom dual 2.5" tip muffler with twin 2.25" pipes.
1kw = 1.34 hp
so peak to peak is 197 whp to 212 whp which is 8% but there is a 22% gain at 4000rpm
E30Mark
Post Fri Feb 09, 2007 2:00 pm
You just forgot to mention what engine it is... 212BHP @ the wheels ???
PM for details
dazleeds
old skool raver
old skool raver
Post Fri Feb 09, 2007 2:02 pm
says 325is on the printout
assuming that means a 325i sport??
www.oldskoolfantasy.co.uk
GDBN
Post Fri Feb 09, 2007 2:38 pm
Brings a smile to the face when you have one !!
G
I deserve 6 of the best ...
dazleeds
old skool raver
old skool raver
Post Fri Feb 09, 2007 2:39 pm
GDBN wrote:Brings a smile to the face when you have one !!
G
sure does fella
think i may go and tax the sport and give it a thrash
just so i can hear it :D
GDBN
Post Fri Feb 09, 2007 2:40 pm
I can't wait for the summer to come so I can hear it with the roof down. Hardtop drowns out a bit of the noise.
reggid
Post Fri Feb 09, 2007 2:41 pm
it is a 331is (ie 325i sport stroked and bored to ~3.1L) i have so far retained the standard air box, M30 AFM, motronic ECu with custom chip and standard intake manifold but the rest is far from stock. Its still running a bit rich for optimum power but its ok. The intake is now most definately the restriction.
E30MArk BHP is always measured at the crank so thats why i used whp for wheel hp as for what it has at the crank it would be around the 240-250bhp mark and thats with standrad airbox,standard intake manifold, still AFM but bigger M30 model and still plain old motonic with chip.
Jimbob
Post Fri Feb 09, 2007 3:12 pm
Surely power at the crank would be over 250bhp? Currently that would only be around 15% transmission loss, but from figures I've seen on here it's more around (and over) the 20% mark, I thought?
Nice figures for the manifold :)
Ant
Retired Team Member
Retired Team Member
Post Fri Feb 09, 2007 3:16 pm
Geat info there M8 !
what was the torque like ?
maxfield
Post Fri Feb 09, 2007 3:17 pm
My dads is about 220 at the wheels and 270 at the flywheel if that helps.
Sounds good you goin ITBs?
reggid
Post Fri Feb 09, 2007 10:32 pm
Ant wrote:Geat info there M8 !
midrange and topend torque are excellent, down low its noticabily better than stock but not as much as i'd like.
reggid
Post Fri Feb 09, 2007 10:39 pm
maxfield wrote:My dads is about 220 at the wheels and 270 at the flywheel if that helps.
not short term as too much $$. A better ECU allowing the AFM to be ditched and a more control over the maps will come before ITB's. Anyone got ideas for a standalone ECU besides MS thats works well with these cars.
Demlotcrew
Post Sat Feb 10, 2007 9:10 am
Maxx alpha-n is not stand alone but will offer better than stock everyday drivability.
Andrew
