Jimbob's thread
HenryM3
Well Jimbob, I finally managed to get onto the ZONE. Glad you enjoyed your ride. Your lucky we only talked for an hour, I usually keep people talking till they collapse with fatigue. Thanks everyone for all the nice comments about the car. I suppose someone had to dislike my wing mirror LED's. All the credit goes to IAN who supplied all the information on the bits needed, wiring diaghrams for the loom and EWS etc etc. I threw some spanners at it and fired up the soldering iron. I read elsewhere about reliability problems with this conversion, can't agree, this one and as far as I'm aware Ian's has been totally reliable. Of course after the engine and gearbox was put in and it was running my poor wife [god bless her] thought I was finished. Still doesn't understand when I tell her it will never be FINISHED. Jimbob's right, it has a big brake conversion from USA. Everything that was sold in UK would have ment geting rid of the deep dish wheels because of the calipers. The one's from USA are 350mm with AC Cobra calipers. I'll post some pictures when Jimbob get's his arse round here and shows me how, cos me and computers don't get on so well.
HenryM3
HenryM3
SilverShadow
- Hartge Crew
Henry welcome to the zone mate!!
You have such a lush car!
Make sure post some pics of the beast!
maxfield
I think a friend of mine would like to know about the brakes.
Also is the strut brace custom ??
Oh the car looks awesome btw
and welcome
and welcome
dazleeds
- old skool raver
welcome henry
read that post an am totaly in love with your car
nice to see that the effort didnt end under the bonnet
excellent work fella
www.oldskoolfantasy.co.uk
E30Mark
Good to see you back online Henry!
See you at the local meets soon?
PM for details
PM for details
Ziggy
HenryM3
If your mate does want to know about the brakes just let me know and I'll dig out the paperwork. The strut brace was origionally a sparco that fitted with the S14 engine. I cut the ends off, turned them round. ie the bit that bolts onto the tower on the left side is on the right and right on the left. [to get the angle right for the bar going straight across] Then a new bar was bent to clear the engine, the car jacked up in the middle and then the bar ends filed to push fit, spot welded before removing and welded properly. If you could find one to buy then buy it cos I spent hours and hours filing to get it right.
HenryM3
HenryM3
maxfield
I will point him this way he has the same wheels as you
I think my dad will have to buy one he's been too lazy to work on the car
bobafett
Welcome Henry,
God thats some work done on your car, fantastic stuff.
Who did the trimming inside.
What ?! Drive straight officer......It's an E30 !
It's the Ultimate Drifting Machine.
ed325i
Henry was your M3 was in a bmw mag ? Cant remenber which one.
Jimbob
Hi Henry
Give me a call if you get stuck with the pictures, I'll write a step-by-step with photo's if need be, will only take a few minutes.
I think your car has quite a fanbase on the Zone now
buster
Hello Henry,
Love the car,seen it in a bmw mag a few years ago (last year maybe ?).Theres a few of us on here now with s50 conversions so your not alone
Ian also supplied the wiring info for us ! Ian haynes=s50 guru
cheers
andy
cheers
andy
HenryM3
To answer the last two questions the trim was done by a guy in Nottingham. I put the seats and door cards in an estate an took them up there. seats are good but you could pick faults with the door cards.
Yes it was in BMW Performance mag a few years ago. They strapped some timing gear to it and it hit the road speed limiter at 158.6mph and lapped the circuit 1 second a lap quicker than an M3CLS. I have too admit here that a BMW track day instructor was taking me round when those times were set. We only managed 3 laps till the brakes caught fire. Hence his comment. "great car shame about the brakes" That's why it's now got the big brakes.
Henry
Henry
buster
id be interested in where you got the brakes from in the states.Theres no room for 4 pot calipers behind these bbs wheels,mind you the caliper is quite hefty for standard ! E30 m3 struts going on soon.
HenryM3
Jimbob, post your idiots guide? cos it's all gone to a bucket of poo at this end.
Henry
Henry
m3ben05
Jimbob
Henry, I'll sort you out a guide and email it to you, I've got football practice now though so it won't be until late this evening.
By the way, your email address has been changed on the Zone now to your proper one.
ian332isport
Hi Henry,
Good to see you back on the zone
Have you had any joy getting the E36 cluster to work yet ?
Ian.
Ian.
HenryM3
Hi Ian, I've played with that instrument cluster till I thought I was going mad. I can get all the warning lights to come on but no needle sweep. For example:-
Pin 4 brings on w/l's minus temperature gauge.
Pin 3&4 brings on everything.
If pin 3 is introduced after pin 4 then the oil pressure gauge sweeps.
No hint of movement from any other needles. I've tried various combinations with no joy.
I was wondering if it made any difference that the live feed is "hot at all times" rather than "hot on accessory" I had contemplated giving up on this one but that would grate a bit.
Henry
Henry
HenryM3
M3Ben05 & Buster The brakes come from Ireland Engineering I've just looked on their site and their still there but there 330mm with todays exchange rate about £700. Of course there's always the chance you'll be nobbled by customs, I was an you just have to pay, however Ireland know this is likely an if you ask after you have payed will reduce the invoice price.
The brakes are twin piston floating calipers with a huge swept area, discs are grooved they come with s/s hoses. The only problem was that the little counter sunk screw hole doesn't line up with the one on the m3 hub. I took the strut off, secured the disc to the hub with the wheel bolts and drilled and taped some new threads. By the way they don't come painted.
At the rear I put on Zimmermann x-drilled from G & S. I consider that I have a great pedal feel and the brakes are noticably better but like Ian I have a hydraulic system, although I doubt it makes much difference to overall performance. Be warned, if you go on this site you'll end up like a kid in a sweety shop. Just type in Ireland Engineering and then on to the E30 bits.
Henry
Henry
E30Adam
Welcome Henry, good to see you made it here.
I hope you realise that you'll be hooked for life now!
Rosc0PColtrane
http://www.e30zone.net/modules.php?name ... ic&t=39439
Linky to pics taken last June of Henry's car, inc engine bay.
Henry, I still have the originals if they're any use to you
m3ben05
Gortour
Wonderful pics from blatantarrogance.
I LIVE in Poole and knew nothing of this.
Was it a 'monthly meet' or an actual show that I managed to miss?
Welcome back to the Zone Henry, I look forward to seeing your lovely car in the flesh some time soon.
Jimbob
Henry, I'll email you the document (for a quick guide into uploading/hosting photo's then getting them to appear on the Zone) in the morning as I need to sort it out a bit at work, it'll be sent before 9am so if you don't get it when you check your emails give me a call. I'll print it off and drop it round.
Gordon, I too knew nothing of this car until yesterday!
Pal318is
See your car at Brooklands Henry, truely stunning.
Well Done.
Welcome too
Pal
Well Done.
Welcome too
Pal
Pal
[img]http://
[img]http://
Rosc0PColtrane
Wheels are 18's.
Cheers fdor the comments about the pics, gotour. The meet was the first at what was meant to be a monthly meet in the Poole area. Meet in a park with a posh house, can't remember what it was called, Poole Park, I think.
I believe the meets you organise are the latest incarnation of what didn't continue last summer, IIRC, Ziggy tried to restart them last Autumn. Thankfully, someone someone like you has taken the mantle to keep the meets going!!!
Gouki
Welcome mate i really like this car, the ultimate M3!
Splondike
Henry welcome aboard. The car is the danglies mate.
Mark.
Gortour
Thanks for the comments blatantarragance. The meets only work if people can be bothered to turn up though. I must say though, I have been VERY lucky with attendance numbers...
Thanks to all who bother.
4th March is the next meet Henry, feel free to join us mate...
http://www.e30zone.net/modules.php?name ... ic&t=57391
HenryM3
The wheels are Rondell 058's 8.5x18 with 225x35's The suspension was Eibach springs and Koni hydraulic dampers. I've just replaced the dampers [december] with Koni gas top adjustables. A vast improvement but more noticable because the others were shot. Bloody expensive too. Roll bars are standard but with poly bushes as is the rest of the suspension. The top mounts at the rear are E46 M3 cab with ZM coupe strenghting brackets, these have now been replaced with a strut brace. Out of interest the standard top mounts lasted about a month after the conversion before they tore themselves in half.
Henry
Henry
