5 Series Diff in a E30????
clubfx2
Post Thu Feb 01, 2007 5:57 pm
I accidently bought a 5 series 3.73 LSD for my E30... Has anyone been able to adapt this to work on an E30.
I have read on some sites that it can be done by changing the back plate and output flanges.
Has anyone done this???
Regards
Clyde
Go everywhere sideways...
Chris-W
Post Thu Feb 01, 2007 6:00 pm
E28, yes. Change cover & output shafts. E34, not without major axle work.
clubfx2
Post Thu Feb 01, 2007 6:11 pm
So you have done this then????
Regards
Clyde
Chris-W
Post Thu Feb 01, 2007 6:21 pm
Nope - but if you search there are details of the E34 axle conversion on the Zone.
ed325i
Post Thu Feb 01, 2007 6:25 pm
Chris-W
Post Thu Feb 01, 2007 6:26 pm
As if by magic!
clubfx2
Post Thu Feb 01, 2007 6:28 pm
Its an e28 Diff I bought, any advice is appreciated...
Regards
Clyde
smooth
Post Thu Feb 01, 2007 6:56 pm
clubfx2 wrote:Its an e28 Diff I bought, any advice is appreciated...
Didn't someone already reply that all you need to do is change the cover and the outplut flanges? What more advice would you like, Just bolt it in...
clubfx2
Post Thu Feb 01, 2007 7:36 pm
After anybody who has done this conversion successfully.
Regards
Clyde
johnl320
Post Thu Feb 01, 2007 9:57 pm
I've done it to a 3.07 E28 diff from a 525e. Change the back plate and output flanges.
Andy325i
Post Thu Feb 01, 2007 10:04 pm
:lol:
The E28 M535i 3.07 lsd deffinatly doesn't fit without modding the car!
Andy
smooth
Post Thu Feb 01, 2007 10:05 pm
johnl320 wrote:I've done it to a 3.07 E28 diff from a 525e. Change the back plate and output flanges.
Why are those bolts backed out?
I heard it wasn't good to do, is that not true?
Andy325i
Post Thu Feb 01, 2007 10:13 pm
clubfx2 wrote:I accidently bought a 5 series 3.73 LSD for my E30... Has anyone been able to adapt this to work on an E30.
There are 3 sizes of BMW diff (at least for 6 cyl cars)
Small (E30 320i 4.10 for example)
Medium (E30 325i 3.73/3.64 LSD etc)
and the larger type fitted to the quicker 5 series and seven series afaik (M535i/M5 etc)
Cabrio
Post Thu Feb 01, 2007 10:15 pm
Has anyone got the tech diagrams and specs for the welding plates etc!!
Andy325i
Post Thu Feb 01, 2007 10:21 pm
For reference:
An E30 325i rear plate on a M535i diff:
Andy
johnl320
Post Thu Feb 01, 2007 10:26 pm
Its only drive shaft bolts in place so I don't loose them. I did'nt realise he had gone and bought a large case diff. Never mind
john
clubfx2
Post Fri Feb 02, 2007 8:25 am
Thanks John, hopefully I am on to a winner here, will let you all know how I get on.
Regards
Clyde
clubfx2
Post Fri Feb 02, 2007 10:24 am
Its from an '87 525i, S3.73.
Taking receipt for it today.
Regards
Clyde
clubfx2
Post Fri Feb 02, 2007 10:59 am
Diff wasn't an LSD and was the big 5 series casing.
Still on the hunt....
Regards
Clyde
clubfx2
Post Fri Feb 02, 2007 1:22 pm
Just found a S2.93 Diff, how will this work on a 325i with stock gearbox?
Regards
Clyde
Post Fri Feb 02, 2007 3:16 pm
badly waaaaaaaaay to long
johnl320
Post Fri Feb 02, 2007 4:02 pm
As Jhonno said, tooo long. The reason I'm using a 3.07 is cos I've got a dogleg box
john
Post Fri Feb 02, 2007 6:24 pm
clubfx2 wrote:Just found a S2.93 Diff, how will this work on a 325i with stock gearbox?
It will be crap, for you winkeye
clubfx2
Post Fri Feb 02, 2007 6:41 pm
PM'd you Dan
Regards
Clyde
