There ya go, not the best write up, but it only took 25 mins!
This method worked for me as a safe and easy way to get the engine and gearbox out of an E30 without assistance from other people.
Undertaking this procedure presupposes that you've disconnected everything from the engine which attaches it to the bodywork including fuel, wiring, hydraulics and the prop (although I didn't disconnect this when I did it opting instead to drop the centre bearing).
Lifting a car to this height can be dangerous so be sure you know what you're doing before starting. I'd suggest that you walk the car up onto the axle stands by raising each side in turn by a couple of inches rather than just going for it.
The axle stands I used came from Screwfix and cost £19.99 when I bought them. They're rated to 6 tonnes each and have an extremely wide base and sturdy saddles. I'd recommend you buy something similarly robust before attempting this in the interests of safety. I've not mentioned the jack I used as I'm sure you can all come up with your own take on that
You'll note from some of the pictures that the saddles of the stands are damaging the cills of the car. I wasn't concerned about this as the shell's being scrapped but you'll probably want to arrange some protection for your shell.
SO! Without further ado, here we go.
You need to go to B&Q and buy some M10x1.5 studding. You can buy some M10 washers and M10 nuts too.
I cut mine into 500mm lengths:
Having got the car up on axle stands, it's time to take the front suspension off:
To support the back of the gearbox, I used a scissor jack and then undid the bolts securing the gearbox crossmember.
Once you're ready, take out one of the subframe bolts and replace it with a length of studding. Wind the nut up so that it takes the weight the bolt used to:
Work your way round the other bolts ONE BY ONE replacing them with the studding:
Now you're ready to start lowering the subframe, you can see it starting to leave the body in these pics. BE SURE THAT THE STUDDING IS NOT COMING UNSCREWED FROM THE CHASSIS AND KEEP THE WEIGHT ON EACH STUD AS EVEN AS POSSIBLE!
Once the subframe's on the ground (or sheet of ply wood as I opted to use) you'll notice the studding's taken on a bit of a curve:
All you need to do to get it to release from the subframe is jack the car up a little bit more. Mind out though as it'll BOING out of the subframe.
Finally, jack the car up some more so that the front of the car's about 700mm off the ground:
Then, pull like mad to get the engine out from under the car.
Refitting is the simple reversal of removal
