Any spray painters in the house ?
m-dtech
Unapproved Trader caution
Post Sat Jan 27, 2007 12:09 am
I want to spray my car and just looking for some hints tips and mix ratios.
Just using normal celluose paint.
I have a reasonable compressor and a few paint guns.
I painted an old tractor before and got a good finish but hope to get better on the car.
cheers
m
candyman
Post Sat Jan 27, 2007 8:59 am
No offence mate but cellulose is such an old way of doing things would be easier to use two pack ,can u get use of an oven for a day ??? and get someone to put the paint on for you ? would not advise you to use cellulose as unless you know exactly what ur doing can encounter loads of problems .
what area you in surely someone close to you from zone will help you into 21 st century lol !!!!
:) Stuart
bazza93
Post Sat Jan 27, 2007 11:02 am
as candyman say's mate lot of hard work ie flating polishing ect, also cellulose might be hard to get hold of now as paint companies are fasing this out as its bad for the enviroment, 2pac is the way to go but you don't neccesrily need an oven as from experience from working for a painter friend of mine they just used different types of hardener, ok an oven bakes it on and its quicker, but it depends on how quick you want it done.
also there is another paint coming on the market and its water based, even better for the enviroment, what i would say to you is ask around and talk to the painters and ask about all 3 ways of painting your car and ask how difficult each proccess is and this should help in your decision.
goodluck :D :cool:
will be back in an E30 oneday soon !
THE BMW 3-SERIES. IT'S WHY SOME ENTHUSIASTS ARE MORE ENTHUSIASTIC,
cliffybabe
Powered by Nelly
Powered by Nelly
Post Sat Jan 27, 2007 11:04 am
im sure dips will be on this soon :cool:
marty1979
Post Sat Jan 27, 2007 12:12 pm
Give MRLEE a shout, he resprayed his motor, and it was his first attempt at spray painting 8O He did an awesome job.
Towards the bottom of the page.
http://www.e30zone.net/modules.php?name ... ic&t=55995
Loony
Post Sat Jan 27, 2007 4:50 pm
When i was a sprayer they were thinking of banning two pac not cellulose and going onto water based,can you still get two pac then?.
If you are going to spray it the more time you spend on preperation will reflect in the end result.Buy or hire a d.a(air powered orbital sander)then sand the whole car down to smoothe the paint off.If you are using filler on it take it down to bare metal in that area never put filler on top of paint.If there are rusty areas sand it down to bare metal around that area.Any area that you sand down to bare metal should then have the paint feathered out around it to prevent a nasty lip in the paint.If this is done correctly you will see different coloured paint rings as you sand back through the top coat and primer etc.These areas should then be primed 3 times slowly overlapping the paint to blend it all in.If you are doing the door shuts its best to remove the doors and make sure the shuts are sanded down and cleaned fully with degreaser.For the best results its best to remove all windows other wise you have to try to bend the rubbers back and hold them back with tape.Once its cleaned all over its time to mask up and spray it.I would recomend you clean it all over with pre clean 1st then use a tac rag to remove and fine dust or dirt on the surface.When it comes to spraying start of by doint the whole roof then work your way round the car as quick as possible,you need to do it in one go or you will end up with overspray issues.When i worked in the garage we use to flat and polish a few paint jobs to remove imperfections so its not a big issue if you had to flat and polish it.When your spraying try to get a nice even wet finish on the car as some people tent to hold the gun to far away and the finish ends up to dry or rough.As for paint ratios etc most places will mix the paint ready for you to go home and put in the gun and spray.If you do flat and polish it try to get a decent mop and buy some g3 to polish it up then use a normal car polish on it afterwards.Hope this helps in someway.
m-dtech
Post Sat Jan 27, 2007 7:50 pm
cheers guys,
candyman, i live in scotland and i dont have access to an oven i just have my barn lol
I have the paint already, and it is celluouse
cheers loony ;)
i will be spraying the bare shell so not got much to mask :)
buying paint direct from paint shop so will is un-mixed.
RJB6
E30zones oldest newbie
Post Sat Jan 27, 2007 8:58 pm
Hi there we all have to start somewhere I have two dvd's one on how to prepare a car and the other is on how to paint the car,if you pm me your name and address I stick a copy of them in the post for you.Good luck don't forget some before and after pictures of you project.
All the best mate
Roy
DON'T FORGET THE BMW WEEKEND JUNE 9TH & 10TH 2007
ed325i
Post Sat Jan 27, 2007 9:08 pm
You can only just still get cellulose.
I am going to use water based paint with a 2 pac laacquer.
candyman
Post Sun Jan 28, 2007 3:26 pm
Hi loony can still paint two pack paints without an oven and the benefit is that if you use a basecoat colour and lacquer it you wont be eternally polishing it to keep it bright and will be better against the elements ( weather etc etc ) If you want some guidance pm me with your number and il talk you through what you need to do
hope this helps
Stuart
marty1979
Post Sun Jan 28, 2007 4:00 pm
Don't forget, with two pack you need a good ventilation mask, preferably an air fed mutha.
WillG
Post Sun Jan 28, 2007 4:21 pm
you shouldnt be able to buy two pack anymore, i heard its all got to be water based from 2007 on
candyman
Post Sun Jan 28, 2007 9:23 pm
WillG wrote:you shouldnt be able to buy two pack anymore, i heard its all got to be water based from 2007 on
Can still buy two pack but bodyshops have to be compliant by 2007 ( which of course i am , and have two pack and water based colour schemes )
they are still selling whatever two pack stocks are left until they run out and it is only the colour tinters for basecoats and solid colours that has new legislation can still use two pack lacquers ,which is great because the paint companys have not sorted a good water based lacquer yet :D
RJB6
Post Mon Jan 29, 2007 7:55 pm
The guys that pm me I have pm you back.Will do them asp,bit low on discs so as soon as they arrive i'll get straight on with doing them ok.
Try to get them off for the weekend if not be early next week.
Roy
RJB6
Post Mon Jan 29, 2007 8:13 pm
These are some pics of my mates car,that I sprayed for him after watching the dvd's winkeye ,I'd never picked a spray gun up in my life,don't think I made too much of a bad job of it.Made a few mistakes but shall know for the next time. :roll: But he was happy. :D
Got a back door from the breakers cos he had a nasty dent in it.
What do you think guys?
whippy
Post Tue Jan 30, 2007 10:21 am
sweet job! what's that rover tahiti blue?
ventilation, that explains my headache!!!!
Gibbo
Post Tue Jan 30, 2007 11:46 am
I've just had some spray work done by a guy in Essex. He's just setting up his business and seems willing to offer up good deals. I'm amazed by the quality of finish. Can't see where he sprayed in the new stuff, matches perfectly, he even sorted the odd bubble spot without any additional charge. So much better than a pro job I had done on the rear arches a couple of years back. I hope to get him to redo this work now too.
Chris - 07904933588. Just mention you heard via recommedation on the e30 zone.
