Will these work with standard shocks, or do they have to go on with the H&R kit ones?
Cheers, Ian
H&R cup kit springs
wildeian
cliffybabe
- Powered by Nelly
they will work on standard shocks as far as im aware mate, Ask M5piolt (Sal)
TW166Y
no good for the 60/40 drop mate but the 35/35 ( i think it is) you'll be fine.
You'll need uprated front shocks if they are 60/40 springs dude
Saying goodbye to 4-pot wrongness
wildeian
Even if they are part of the 'cup kit', not just the standard lowering springs
TW166Y
they dont sit inside a cup or anything mate
Ziggy
They'll 'work' but won't be ideally matched, probably won't last as long & may fail the MOT if you get an ar$ey tester. No need to go with the H&R ones particularly (although it's obviously a good combo!) - any suitably uprated (& shorter) ones will do the trick. Springs & shocks are independant in terms of how they fit, it's just how well they work together...
Might as well do it all in one go...
eko
- Old timer
Ian,have you already got these springs?
If so fancy a swap for some near new H&R -35mm?
wildeian
I haven't got them eko, was thinking about buying them off some fella on ebay who doesn't have the shocks.
eko
- Old timer
Ah right,probably the ones Twiggy gave me the link too?
Did send him the same message as you but he wants an out right sale and i just aint got the cash to spare right now
Not to worry,ill stick with 35`s for now!
TW166Y
if they are the ones that are 60mm up front that are on ebay dude, you'll bottom out like a good un on standard shocks.... and oh yeh, you WILL fail an m.o.t
Some idiot lowering the mrs e30 with 60mm springs and kept stock shocks, banging everywhere dude. and just for the record it also failed its m.o.t because the shockers were doing NOTHING!
wildeian
-35 is better than whatever the hell 'moon rover' springs I've got!!!!
