Tech 1 Mileage?
GingerTim
I found a tech one D reg that'sdone 168000 mile's, alot i know but sound's mint. It's had alot of service work done (disk's and pad's etc) sound's like it's had a caring owner. It's up for £1700. Do you recon it's worth it? ? ?
Theo
Errr, could be, but probably isn't.
Step 1 - Check if it's rotten.
Step 2 - Actually that's about the only step I know, I've never seen one that isn't!!!
Chris-W
GingerTim
It's had both arch's done and then both side's painted to tidy it up 2 year's ago.
ok so there is no rust you can see!
Step3: investigate further for rust which is not visible. These are the worst rusting E30's going and can rot big time, no where on the car is immune!
Theo
It will almost certianly have issues. The one I've just scrapped had new rear outer arches. But was rotten is so many other places. You really must tread carefully, that is alot of money to spend on one with any rust issues.
GingerTim
Fair play you guy's know how to scare someone! Right i'll follow all 3 step's when i go for a look.
oguz327
- Captain Armco
Step 4, check for rust again and re check what uv already checked
Milage isnt really an issue as long as all the obvious stuff is ok.
snoops
- Major Helmet
check under carpet, etc and then check for rust AGAIN
oguz327
- Captain Armco
To be fair tech 1s rust no more than any other chrome bumper, it just luck of the draw wether its been looked after, had bad accidents/repairs, garaged or where in the country its lived, just make sure you check for rust.
Like snoops says try and check under the carpet (if you can), get the rear seats out, boot trim and have a gander not easy to do while viewing (owner may be offended) a car but if your spending 1700 sheets at least check as many area's as you can.
Good luck with it dude, there not all completely fooked but good ones are very rare!
