c2 alpina not running properly
tonym3
Post Wed Jan 17, 2007 9:01 pm
can anyone give me advice on how to adjust my airflow meter it wont tick over properly its hunting it runs ok but it revs up and down when ticking over.
M5pilot
Post Wed Jan 17, 2007 9:05 pm
You should not alter the AFM setting. This should only be done by a garage with a Gas analyser.
Sounds like your Idle Control Valve needs cleaning or changing.
Sal
gary
Post Wed Jan 17, 2007 10:08 pm
Try spraying carb cleaner into the AFM to clean it out
Post Wed Jan 17, 2007 10:10 pm
Tony you need to elaborate on you posts!
Nelly
Gumbo
Gumbo
Post Wed Jan 17, 2007 10:11 pm
Might be as simple as a split in one of the hoses - especially if you had the air filter changed or anything to do in the afm area?
Neil.
"I F**KING LOVE YOU GUMBO"
