Front Shock's, Which One's?? Update
cliffybabe
- Powered by Nelly
Hi Guys
I have got to buy another set of front shocks for my cab, trying to decide which one's to go for.
The cab has a 40mm drop with bilstein springs.
ECP do standard Bilstein OE (gas shock) for 39.99+vat each has anyone got these are they any good??
Alternativly I have found a set of front replacement sport shocks ie Mtec one's for £125 fo touring one or £110 for saloon one's which are also Bilsteins
Which one's would be best for my cab?? If i go for the sport one's should i go with the touring or the saloon shocks
Thanks for your help
Neil
Neil
cliffybabe
- Powered by Nelly
Also found some Koni'
KONI
Red Special Front Shocks
Product code: K-86-2277Sport
FRONT KONI SPECIAL SHOCKS (red) Details - For McPherson struts with housing ÃËa 51 mm - upto 8.88 see info. This unit is a McPherson strut cartridge.
KONI
DaveD
- E30Zone Wiki Specialist
I have gone for GAZ ,which seem to have a good rep and are not too hard, but i cant tell you how good they are 'cos i haven't fitted them yet. £67+vat
M5pilot
Go for the Bilstein sports.
They are £104.99 on the zone shop each.
Sal
Sal
blingsta
- Boost Junkie
Are you looking for new ones Neil? if not theres some complete M-tech ones on e-bay for £40
cliffybabe
- Powered by Nelly
I want new one i hav etried th e2nd hand route with no joy,
I've been quote 125 for the sport mtec style strut for the pair which i think aint bad
M5pilot
£125 for the pair! Where from?
cliffybabe
- Powered by Nelly
Sal, europerformance quoted me that
yeah right!
Neil bilstein don't make springs
stuartgallafant
cliffybabe
- Powered by Nelly
Si these one's have bilstein written on them mate, I have a pic of them somewherestuartgallafant wrote:why does he have them then, with bilstein written all over them...Simon13 wrote:yeah right!
i must of made it up then, they will be made by another firm.
Much like H&R paint their shocks in their colours even though they are made by sachs..........
cliffybabe
- Powered by Nelly
Si what do u think sport shocks or the normal bilstein shocks??
DaveD
depends how hard you want the ride and having just had a look at eurosports,,its how much you want to pay...their website quotes £125 for 1
Demlotcrew
I bet for £125 you are getting the non inverted gas bilstiens which cost £39.99 + the VAT each.
These are not a touch on the Sports which are about £125 a corner.
I think for you the best option is to go for the Sachs Mtech dampers sold by GSF.
Andrew
Andrew
i would say it's a cab and it will never handle like a saloon/touring
They are for crusing so i'd want a nice comfortable ride not stiff bilsteins
BristolBulldog
Same car neil. I used to have a set of standard bilstein hd shocks for the cab from ecp, with venturi springs. was exceptionally good given the cost.cliffybabe wrote:Hi Guys
Neil
I now run spax psx kit. also very good.
you can get the whole kit for around the 300 mark delivered.
shocks fully adjustable.
Last edited by BristolBulldog on Wed Jan 17, 2007 11:35 am, edited 1 time in total.
BristolBulldog
So many people say that. But a bit of tweeking and i would keep up with the best of them.Simon13 wrote:i would say it's a cab and it will never handle like a saloon/touring
I understand the principal of the argument, i just don't think its valid. you only need a little bit more skill to make up for the difference, and u get to do it with the roof down (in our lovely cold damp weather lol).
but if i tweek my saloon or touring the gap stays the same. Tourings don't have scuttle shake!
BristolBulldog
in that you are correct. what i am saying is that there will be a measurable difference, granted. same driver, same spec etc. But the actual difference over a whole track distance for example would be so minute that i think the argument is practically void.
I played with sports before, and mine wasnt a sport. It wasnt a fair comparison, as practically no e30 will now be in identical condition.
You can also remove most skuttle shake as well. I found alot of it comes from the standard exhaust wierdly enough. stiffening the mounts, and re-enforcing the system makes a massive difference.
and i know for the tiny price in performance, i can do it with the roof down. not for posing, just the sheer enjoyment of it.
If i was to build a race car, then yes, i would stick with coupe/ saloon as every second (or parts of) count.
Demlotcrew
There is no way a cab would hanle like a top tint full stop.
You would need to brace the cab so much that the benefit would outweight the extra weight the bracing would add.
Andrew
Andrew
BristolBulldog
i look forward to seeing you on a track day to suprise you. (when i finally finish the bloody thing)
i'll bring my touring aswell then!
tourings are probably the stiffest E30 shell aswell
BristolBulldog
yep all sounds good. Issue being the amount of work each has done (or more importantly not). Would be good if we could match a 335 cab, touring and saloon up well.i.e. similar suspension etc and see how they do. Will never know down to driver, but hey, thats where the fun is right?
Isnt the touring heavier than the standard e30? i think the cab is 80kg heavier. I've removed alot of that difference, but with the suspension mod's i bet i have put it back on again.
And as for the m3 kit, well thats gonne weigh a bit, but again, hopefully offset by the much wider track i will get.
hoping to have it finished for summer, and its headed straight for the first track day. (this will be the first version, i'm doing a complete refresh over xmas 07 which will see the proper engine put in, and a full respray.
Barnz
- Guildford Geezer
Anyway back to the thread...
I think Cliffy should go for Sachs or Boge shocks or if he's feeling flush then the proper Bilsteins.... but would make the ride quite hard I think. Had them on an old Audi Coupe I had, boy did it go round corners better!!!
E34 525tds - on the way to replace 325i
E30 / 34 spares
E30 / 34 spares
BristolBulldog
erm, yep. sorry about that.
spence_star
so for a cab to have a low look and a not so hard ride what are the best shocks to buy?
Returned after many years out.
BristolBulldog
you will only get he "low look" from the springs.
Ride wise, i found the venturi springs from ecp to be absolutly excellent (they are also tuv approved). They still handled very very well, but the ride from them was great. This was as above in combination with bilstein hd shocks. all from ecp.
I was running 18's on this setup, so with smaller wheels you will fair much better.
i know that most companies that sell the psx kit can get it custom valved for you for no cost. it might be worth getting the psx kit, and getting it valved to suit your application.
stuartgallafant
cliffybabe
- Powered by Nelly
after reading the feedback im gonna go with standard bilstein replacement shocks, As i dodnt want to loose the ride quality
stuartgallafant
Demlotcrew
No E30 cab came with 'standard bilstein shocks' they were boge or sachs.
Which is what me and stu are telling you to get
Andrew
Andrew
I'm sorry but the ride will be utter sh!te on 18's! peoples opinions on ride comfort vary wildly
i've yet to drive/ride in an E30 with a ride as good as standard (non-M-tech) which either has lowering springs, matching shocks or bigger wheels fitted to it.
cliffybabe
- Powered by Nelly
OK ok im going with the mtec sachs one's then
With the alpina rep's which are 17's this should be cool?
they will be ok with the lowering springs yes if the springs are 40mm
