Next Month Suspension Upgrade
Car-Nut
Post Fri Jan 12, 2007 3:50 pm
After picking your brains over the last couple of months about what set up to get Ive had a chat with Imran at the Zone Shop and have decided to get the:-
HR Cup-Kit with a 35mm drop - have to keep it looking sensible as its my work car and go on MOD sites.
Also going to do the following bushes
Subframe Bushes
Trailing Arm Bushes
Front Control Arm Bushes
Cant wait to get it done as at the moment its pointing up a bit as the back springs are knackered.
Anyway purpose of this thread is I never do any work on my car, it always goes in to be done. :) This time I fancied it doing it myself. :chuckle:
I know sometimes people take photos and add txt and create a web page on certain jobs they have done to there beast.
Have any been done for Suspension Upgrades ??
Oh by the way Imdoing it on my E30 325i '88 :drive:
:cheers:
Clive
eko
Old timer
Post Fri Jan 12, 2007 4:09 pm
I too am running H&R 35mm springs although im using Bilstien shocks instead!
I cant praise this set up highly enough,sits nice/rides well/handles good winkeye
Regards the bushes - I replaced all the bushes on the back of my car last weekend using genuine BMW items.
Word of caution - Unless you are reasonably compitent and have a good selection of tools dont bother?
Trailing arm bushes are easy once you get the arms off but the axle carrier bushes can be a pig.
This time i used the proper tool for getting them in/out but in the past ive burnt them out then had the new ones pressed in at a local garage :mad:
Also the shaft in the middle of the carrier bushes can become siezed where it locates in the shell,take care here because if they break off it can be a b4stard to get them out!!!!!
Hope some of this helps :D
Rosc0PColtrane
Best of luck mate!!! I hope you have the right tools!!
Be careful with spring compressors, Andyboy can vouch for that!! Fecking deadly if you get it wrong!!
My bro is a mechanic, I get him to do stuff which is out of my depth, otherwise I like to have ago at most things!!
toby
Post Fri Jan 12, 2007 5:25 pm
Here's some photos of how to do it. It's a fun job but you do need quite a bit in terms of equipment if you don't normally have the use of tools to be safe.
Not a 325i in the follwing page but bascially the same
http://www.esatclear.ie/~bpurcell/318issuspupg.html
http://www.e30tech.com/articles/
I'd always do a suspension change with someone else more skilled and knowledgable than myself (and with lots of tools).
Do you want to do it for the challenge though?
Car-Nut
Post Fri Jan 12, 2007 6:44 pm
thanks Toby that first link is an excellent site........ winkeye
all replys much appreciated
