front lower wishbone rear bushes
burrows
Post Sun Jan 07, 2007 10:22 am
hi , just wondered what are the best bushes for my bmw.
thanks
Post Sun Jan 07, 2007 11:54 am
E36 M3 ones from your dealer. Either concentric or offset, as you prefer. (Difference is the age of the E36)
burrows
Post Sun Jan 07, 2007 2:30 pm
thanks for your help
stuartgallafant
Post Sun Jan 07, 2007 4:30 pm
do you think the offset ones are better brian?
do the E36 definately fit, or is it best to use E30 M3 ones?
Templ8e30
Post Sun Jan 07, 2007 8:55 pm
E36 use the same lollipops and the wishbone dimensons are the same so they will fit.
I'm using E30 wishbones on the wifes E36 after the horrible rubber mounted balljoints gave up the ghost on the original wishbones. No more tramlining and weird wandering feel from the front end 8)
Cheers,
Iain T
2007 Mazda 6 2.0 estate
stuartgallafant
Post Sun Jan 07, 2007 10:21 pm
so i should get the off set E36 M3 ones then?
