Haven't decided weather to change my boring 14's for 16's or 17's
What is the best suspension set up for fast road dont want the car really low, just to handle better...
Suggestions appreciated
New suspension
Car-Nut
fuzzy
theres 15000 members on here,youll probably get 15000 different answers
gareth
it depends what you're really looking for mate. the m-tech suspension will drop the car about 15mm afaik and should tighten it up a bit. changing your 14's for some 15" BBS or 16" alpinas or something will help a lot too. 17's will generally spoil the handling though.
what is your budget?
Car-Nut
Most probably put Wolfrace Octanes on it as I think they look good with the Zinnober Red body.
The dont do 16's so will most probably get 15's
http://www.wolfrace-alloys.co.uk/c5287.htm
Looking to spend about 4-500£on new suspension
Theo
They are quite nasty tbh - a mint set of 15" BBS suits the car as well as anything, and they are strong and light!
The suspension setup I would recommend would be inverted bilstein shocks, H&R/KW/Eibach -35mm springs and some uprated anti roll bars. But would also be worth looking into sorting the various bushes out as well.
miniblob
I've gone for the H&R coilover setup - you can set it at whatever height suits i think!!
To be fair though, the 2.7 i bought had a H&R cup kit which was also excellent - little bit softer than the coilovers so maybe better suited to everyday road driving!! Not sure on the height but it made it over speed humps ok!!
Make sure you get some fat anti roll bars and a strut brace too!!
And as Theo mentioned, bushes can make a difference too!!
And change those 14's for some 15" BBS or some nice wide 16's!!!!!!
327 Touring with bass!!!
gareth
not keen on the wheels personally... you could get a set of BBS's and professionally refurb them to as-new condition for less than those. i know what i would do!
the H&R cup kit has a good reputation around here, as does the KW kit. have a look through the zone shop (link up the top of the page). i'd also do rear subframe bushes (bound to be stuffed by now!) and any other bushes you can afford. some nice ARB's would never go amiss but you'd be hard pushed to do shocks, springs, bushes and any other suspension joints you find that need attention within your budget.
miniblob
Whoops - didn't see the budget!!!!!!
Have a look out for good used parts in the for sale section!!!
Car-Nut
Budgets are made to be broken !!!
I had heard good reports on the H &R cup kit may take alook at the price
what make do you recommend for bushes ?
Cheers for all the feed back guys
Clive
Clive
orangecurry
BMWCar-Nut wrote:what make do you recommend for bushes ?
Greeny
Go with Bilstien dampers and Eibach springs you will get about a 20-30mm drop but you will keep a very nice comfy ride.
Gone but not forgotten.
('92 325i Cabriolet)
Car-Nut
Nice car Greeny,thats the look of wheels Im looking for polished black with stainless steel rims
Also I want them as they are easy to clean the BBS are a PAIN
to clean
