Rear headrest fitment to a cab ??
lukescott
I have a 318i lux cab 1993. It has no rear headrests, can they be retro fitted ? And if so how difficult is it ? All help appreciated.
E30Mark
Yes they can be retro fitted.
The rear headrests are the same as the front ones.... depending on colour / pattern will determine price and availability.
The fitting kit is approx £15 from the dealer i think...
Rear seat back is held in with two bolts at the bottom, then just pulls up and off, fit the fitting kit, cut through the material on top of the seat, and fit the circular trim piece. Refit seat, job jobbed.
Enjoy
Enjoy
PM for details
PM for details
motorsport
Real easy job, fitted them to mine.
Once you have the retro fit kit from the dealers you will see how easy it all goes together. The rear seat already has a metal frame moulded into the back to accept the headrest retro-fit frame.
Just be carefull cutting through your seat top to accept the headrest legs. Best pushing a knitting needle etc. up through your seat top passing through the inside of the newly fitted frame, this should guarantee you have the best line through your seat for the headrest legs.
Andy.
Andy.
