z3 m diff?
fuzzy
i was looking at this on ebay and although the seller does say it doesnt fit an e30 in one of the question asked,to me it looks remarkably similar to an e30 diff.so does the z3 diff fit the e30?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting
Simon
I believe it's the driveshafts that are different, the diff itself will bolt up fine.
Jimbob
I think you can use the output shafts from an E30 diff and it'll go straight on....I think that's what I was told anyway
this is true! but fuzzy will a 3.15 diff work on your mutant?
surely an M-tech 2 front bumper is top of the list?
Chris-W
fuzzy
im not thinking of buying this one as i already have a spare 3.64 lsd in my shed.i was just curious as to wether the z3 diff will indeed fit for future reference.the tech 2 bumper isnt high up on my priorities as thats cosmetic and i have a white bumper on,thats good enough for meSimon13 wrote:this is true! but fuzzy will a 3.15 diff work on your mutant?
dark_sounds
woah, 3.2 aint it? out of interest, anyone know what kind of power this is suited to to make a good drive?
im guessing with fuzzys this will work really well? or will it cause a fair difference decrease in acceleration??
Directed CompX's 12"... 2off. 1000 watts RMS, dual 2ohm VC. 90£ each!!
8600 Luna Phone 480 POSTED BNIB
Jimbob
This would be a good choice for an M50 conversion. Depends what type of driving you're after, I'm happy with the 3.64!
Demlotcrew
Fitting a 3.15 from 3.25 to my car made it faster.
Andrew
Andrew
fuzzy
i believe that the higher the number the quicker the acceleration,lower numbers would lose out on acceleration but gain top end. me going from 3.91 down to 3.15 would lose me all my credability at the traffic light grand prixDemlotcrew wrote:Fitting a 3.15 from 3.25 to my car made it faster.
Andrew
maxfield
Going from 3.25 to 3.15 gained him 1mph in first gear.fuzzy wrote:i believe that the higher the number the quicker the acceleration,lower numbers would lose out on acceleration but gain top end. me going from 3.91 down to 3.15 would lose me all my credability at the traffic light grand prixDemlotcrew wrote:Fitting a 3.15 from 3.25 to my car made it faster.
Andrew
but u would only fit this diff because u needed this ratio and u were after a LSD with 100% variable lock up. Far better than our old skool 25% jobbies. Plus they are mechanical too
So are the internals the same as an E30 M3 diff?
How much has your rpm dropped at cruising speeds Andrew?
Demlotcrew
The internals are similar but are not identical as the barings seem to be larger.
But there is no reason why the races cant be taken off and E30 ones used on the clutch pack.
With 3.91 5th gear at 3500k rpm the road speed would be 62mph (M3 gearbox). (76mph M20B25 gearbox)
With 3.15 5th gear at 3500k rpm the road speed would be 77mph (M3 gearbox). (95mph M20B25 gearbox)
Thats a 19% difference.
From those figures you can see how a 3.15 is well suited for the M3.
HTH
Andrew
HTH
Andrew
I thought you said you changed from a 3.25
Whats this about mechanical LSD? I thought the BMW LSD's were all the same?
