325is handling what works for you? too much body roll!!
DORAS
Post Wed Dec 27, 2006 10:29 pm
I have got a 325 sport and would like to sort the handling out. i am currently running standard suspension, with newly fitted bilstein shox. poly bushed front lower arms, anti roll bars, and rear beam bushes. i have a front and rear strut brace also fitted. i lowered my last 325 on jamex shox and springs and found the handling good but ride awfull! i am happy with the rear ride height but would like to bring the front down 20mm. i was thinking of just fitting the h&r anti roll bar kit to save the ride quality and maybe so shorter front springs.
what are your thoughts.
ian332isport
Post Thu Dec 28, 2006 7:23 am
If you are looking for a modest drop and a reasonable comfy ride, then something like Eibach springs are your best bet. These drop approx 30mm, but will be way better than the Jamex kit you used previously. Combine that with a set of anti roll bars (H&R seem to be the favourite at the moment, but Eibach also do them), and it should seriously reduce body roll without making it a bone shaker.
If you don't want to drop the back down quite as much, you can get different thickness spring pads to fine tune the height.
Speak to Sal in the Zone shop and he'll sort you out.
Ian.
DORAS
Post Thu Dec 28, 2006 8:41 am
Thanks for the advise Ian. Would you leave the standard shox in it or get a complete eibach kit.
Rich
ian332isport
Post Thu Dec 28, 2006 8:47 am
DORAS wrote:Thanks for the advise Ian. Would you leave the standard shox in it or get a complete eibach kit.
Rich
Rich,
Ideally you would fit matching springs and shocks, but you said you have just fitted new Bilsteins, so I kind of assumed you had already done the shocks. With a modest drop of 30mm, you will probably be okay with your existing shocks. If you went any lower, or used springs any stiffer than the Eibachs, you may risk damaging the shocks though.
Ian.
DORAS
Post Thu Dec 28, 2006 9:07 am
Ian
I'll try the eibach springs first then, they dont cost a fortune and it sounds like they wouldn't be to hard that they would knock my fillings out and maybe get a anti roll bar kit after if its still a bit rolly.
Rich
gooner1
Out humping Reindeer
Post Thu Dec 28, 2006 2:28 pm
Just as a matter of interest how do i measure how much my car has been dropped, do i measure from top of wheelarch to centre of wheel?
