I am sorry to hijack you forum chaps but I am an E36 owner. However i have the M42 engine in my 318is and it first featured in the E30.
Whenever I go on the E36 forums and ask whats the best performance mods they say 'Buy a 328!' This is not an option so come on E30 Owners, tell me how to increase my BHP!
318is succesful mods
appletree
the m42 responds well to a remap and a filter. dont quote me but i think it was 162bhp at the flywheel on a car some one did at chipped UK. The best filter would probably be a ITG one like from the zone shop (see top of page) i have on on mine after i tryed a K&N style thing and lost power!! i did start a thread up about it all, al try and find it for you!
eko
- Old timer
Remove the heater plate from the throttle body.
Swap viscous fan for electric?
Inlet cam timing can be moved a `few` degrees too
Dave_M3
Wat u could do is if u want 2 get good performance out of the M42, Go back 2 an e30 nd get rid of all that excess weight. If u dont feel like that u could put some big bore throttle bodies on 2 off an M3 r sumthin, Hav a look at Tims thread, got over 200 bhp out of his is, altough it is rebored to 2.1
appletree
Found it!! if you look near the end there should be the dyno results
MrDazzle
My iS was tuned by the former owner (Kos)...
He removed the heater plate in the inlet tract (dunn oif the E36 has that bit), fitted a different backbox, changed the air filter and fitted a Viper chip. He then - an this is the important bit - had it remapped on a rolling road. You have to remap on a RR to get the best result.
End effect was 162bhp best run and 147lb.ft. Although, that may not be entirely true, since the car has had a head gasket change at some point and my have been skimmed in the process.
Dave_M3
would the skimmed head make much of a diff in bhp? 162 isnt bad at all though
maxfield
hmmmm
would a skimmed head with the same size gasket increase compresion due to less of a squish height?
but if it was a gasket with extra thickness to take it to standard squish height then nothing would change??
am i talking complete bollocks???
Dave_M3
No, sounds bang on mow come 2 think of it. but I was just wonderin how much of the 30bhp would be because of the skimmed head with a thin gasket
